The red convergence is way off near the left and right sides of the screen. I can adjust the cross hairs vertically but not horizontally. Near the left and right sides of the screen there is a double image (red and green). It look like you're watching a 3D movie without the glasses. The blue convergence seems to be ok. If you could suggest what parts need to be replaced (and what they look like and where they are) I'm game for some soldering. Thanks for any advice you may have.
Go to the following link and click the contact link on the lower left side and tell them your model they will email you with the correct convergence ICs that you need for your model. they also provide free installation instructions with pictures and free tech support when you order the replacement ICs.
http://servicemanuals.vstore.ca/
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
We were having "shadowing" on the picture - red and green. I was told that there needed to be a realignment and to follow these steps:
Press Mute, 1,8,3, Add/Erase, Perfect Focus and then try again until I got the picture into focus. May have to repeat several times. I have tried and tried and now the picture is worse. After it goes through the steps to "perfect focus" there comes a white screen and now there is "bowing" at the top and bottom. I am unsure of what "convergence", "convergence IC's" are I have read some of the other problems/solutions and I don't want to do something to make it worse. Thanks for any help you can offer!
