Sounds like you've wiped all your data. It's a good discipline to keep a regular backup of all your Palm files on the PC so that if this happens you can restore the last backup and re-synchronise. I have had several Palm devices, and all of them have corrupted files at some point.
This morning I downloaded LifeDrive Update 1.0, and when I did a HotSync afterwards, I got an error message saying,
Handheld Tasks application database version not supported.
Handheld Notes application database version not supported.
Now my contacts, memos, tasks, calendar entries and possibly other items are all gone!! This is the core data that is the reason why I use a PDA! I would be totally distraught, except that the data does still seem to exist in Outlook on my PC.
I am running Outlook 2002, SP3 on a WinXP machine. Can anyone help to fix this problem?
thanks,
In order to synchronize with Outlook you need to setup the replication to be with Outlook instead of Palm Desktop.
On you cd there should be a third party piece of software (Chapura). Install the required software and follow the instructions.
Remember to change (HotSync, Custom) settings before you perform your sync or else you will get duplicate records as I did. Good luck.
Support Knowledge Library
Click here to go back Click here to print
Solution ID: 25263
Switching between Outlook and Palm Desktop synchronization
Depending on your device, you might be synchronizing with Outlook using the Palm™ Outlook Conduits, or PocketMirror conduits from Chapura (find out which). Both of these types of conduits are installed and activated when you run the CD-ROM that came with your device.
What do you want to learn about?
* Switching synchronization: Palm Outlook Conduits
* Switching synchronization: PocketMirror Conduits
* Synchronizing partially with Palm Desktop, partially with Outlook
* Note about data transfer
* Macintosh information
* Multiple users on the same desktop computer
These instructions apply to the Palm Outlook Conduits that are included with handhelds released after late 2003. The Palm Desktop installer determines which conduits are activated during the installation process.
If you want to switch synchronization from Palm Desktop to Outlook, or vice versa, you'll need the original CD-ROM that came with your handheld.
1. Insert the CD-ROM into your computer. A window should open, containing the contents of the CD-ROM.
2. From the Discover Your Handheld screen, select "Install Microsoft Outlook Conduits" or "Change synchronization method" (depending on which device you have)
3. Follow the instructions for switching synchroniztion from or to Palm Desktop or Outlook.
4. See our note about data transfer
Remember: Some applications will continue to synchronize with Palm Desktop. Use Palm Desktop to manage applications such as Photos and VoiceMemo
I did search through the forums before posting and the only "solution" I found was to buy Chapura PocketMirror for $30 which I refuse to do. I should be able to sync this palm with Office without having to spend even more money.
Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
