If the problem is only on the neck position it would seem that the switch or the pick up wiring is faulty. a little bit of WD40 on the selector switch will sort if the swtch is gone ...if you take the switch out and check the solder on the connections at the rear of the switch you may see the wire loose or solder point faulty.. just a dab with a solder iron should sort here.. you may need to resolder the connection.
Testimonial: "thanx for the advice! . .t'was a big help. ."
