To connect the Power Inverter, you need to run wires from the battery terminals to the inverter. This might be permanent if you are planning to set this up inside your car.
If permanent you need to choose a location where to install it and run the wire until the place where you are installing. Make sure to disconnect the negative terminal from the battery, and when running th positive cable avoid contact with metal.
There are other options such as running a gel battery in parallel and from this battery a cable to the inverter. Advantages are you will not drain your main battery as fast.
A 1000 watt power inverter hooks to the battery terminals directly, not through the cigarette lighter.
