Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings To select a ringing tone for voice calls, select Tones > Ringing tone. To select a ringing tone for video calls, select Tones > Video call tone. To set the ringing type, select Tones > Ringing type. You can also set the device to sound a ringing tone that is a combination of the spoken name of the caller and the selected ringing tone, when someone from your contacts list calls you. Select Tones > Say caller's name. To set the volume level of the ringing tone, select Tones > Ringing volume. To set the various alert tones, select Tones > Message alert tone, E-mail alert tone, Calendar alarm tone, or Clock alarm tone. To set the device to vibrate when you receive a call, select Tones > Vibrating alert. To set the volume level of the device keypad tones, select Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
Settings In this menu, you can adjust various phone settings. To reset some menu settings to their default values, select Restore factory set. Tone settings Select Menu > Settings > Tone settings and from the available options: Ringing tone-To set the tone for incoming calls Ringing volume-To set the volume level for the ringing and message alert tones. If you set Ringing volume to be level 2 or above, your phone rings with the ringing volume ascending from level 1 to the level you have set when there is an incoming call. Vibrating alert-To set the phone to vibrate when you receive a call or a text message Message alert tone-To set the tone to sound when you receive a text message Warning tones-To set the phone to sound tones, for example, when the battery is running out of power
Dear Sir .
Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step :
options:
Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls.
I hope this will works for you.
Regards.
Rizwan.
menu 2 settings 3 tones incoming call alert (set to ringing) ringing tone ( pick your ring tone) ringing volume (set to level 5 loudest) vibrating alert (on) message alert tone (pick tone) instant message alert tone (standard) keypad tones (on) warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok alert for (all calls)
Hi Kathnicks2 Have you checked your profile if its in silent mode? Also check the settings and in that check if you have selected the incoming call alert as ringing or vibrate. You can also check if your mobile is ok by trying to listen to ring tones in general. So, if you are not able to just listen to ring tones, then you will have to meet a service person who can get it right for you.
hi!
check your mobile is in silent mode!
After that goto tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume!
or
Otherwise goto profile personalise setting tone setting->ringing mode->you keep it is ringing->select alter for all calls->and than check volume
Good luck
