First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private)
loadTOCNode(3, 'moreinformation');
The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
Local NTFS Permissions:
Network Share Permissions:
Level 2 (Default): My Documents (Default)
The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
Level 3: Files in shared documents available to local users
Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
Level 4: Shared on the Network (Read-Only)
Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
Level 5: Shared on the network (Read and Write)
This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
The first time you connect to a network, you'll be asked if you want to turn on sharing between PCs and connect to network devices such as printers. Your answer automatically sets the appropriate firewall and security settings for the type of network that you connected to. You can turn sharing on or off at any time.
Press and hold or right-click the network you're connected to, then tap or click Turn sharing on or off.
Menu used to turn sharing on or off
Do one of the following:
Choose Yes, turn on sharing and connect to devices for home or small office networks, or when you know and trust the people and devices on the network. This setting allows your PC to connect to devices on the network, such as printers.
Choose No, don't turn on sharing or connect to devices for networks in public places (such as coffee shops or airports), or when you don't know or trust the people and devices on the network.
Turning sharing on prepares your PC for sharing files and devices on a network. For more information about sharing with other people on your network, see Sharing files and folders on a network or a shared PC.
The network sharing setting is only available for WiFi, Ethernet, VPN (non-domain) and dial-up (non-domain) connections. It's unavailable for domain networks. On VPN or dial-up connections, you must connect to the network first, then press and hold or right-click the network name to change the network sharing setting.
Turning on sharing changes your firewall settings to allow some communication, which can be a security risk. If you know you won't need to share files or printers, the safest choice is No, don't share or connect to devices.
Choosing No, don't turn on sharing or connect to devices blocks the following applications and services from working: PlayTo, file sharing, network discovery and automatic setup of network devices.
Network discovery is a setting that affects whether your computer can see (find) other computers and devices on the network and whether other computers on the network can see your computer. It's one of several settings that are turned on when you turn on network sharing. You can turn network discovery on or off independently of network sharing, but we discourage this. Here's why. If you're connected to a network in a public location and you decide to turn on network discovery but leave network sharing turned off, the network discovery setting will be on for every public network you connect to from then on. This wouldn't be safe. That's why we recommend using the network sharing setting instead.
However, if for some reason you need to turn network discovery on or off independently of the network sharing setting, here's how to do it:
Tap or click Turn on network discovery or Turn off network discovery, then click Save changes. You might be asked for an admin password or to confirm your choice.
