I have a new Poulan Pro Self-Propelled Lawn Mower Model: PR625Y22RP. The grass catching bag is attached the door is open but no grass is going into the bag. There is a plug on the base of the mower does it have to be removed for the mower to catch grass rather than mulch.
This is a 21" mower, meaning the blade is 21" long (maybe only 20.5") and it will cut a 21" wide path of grass. Measure the width of the path that it cuts in the grass. If it is less than 21", then the mower has the wrong (too short) blade on it. It may just have a configuration of deck and wheels that make it look like it's not cutting as wide as it should.
grass will build up over time on the underside of the deck possibly impairing the flow of the clippings. I use a flat screwdriver to scrape the big clumps of grass off the underside.
where is the oil on under there ??if it's on the shaft where the blade attaches the the oil seal is bad...that's caused by old oil, which is too thin and seeps out...try changing the oil first...
When you mulch you can only cut 1/3 of the grass off. If the grass is 3" high you can only cut 1" off.If you are cutting more grass of than you are leaving there is no place to hide the clippings.A general rule is if you notice clippings and clumps beginning to lay set the mower up one notch at a time until the clippings are hardly noticeable.If you like a real low cut then mulching is probably not for you,you will probably want to bag the grass instead.Hope this helps.
Base rotted out
