Motorola Mobility SLVR L7 Cellular Phone Logo
Posted on Jul 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DOES IT SLIDE OPEN AND HAVE A KEYBOARD - Motorola Mobility SLVR L7 Cellular Phone
Anonymous
Level 3:
President:
  • Master 1,561 Answers
  • Posted on Jul 19, 2010
Anonymous
Master
Level 3:
President:
Answers
1561
Questions
0
Helped
296540
Points
4482
Motorolla L7 do not slide open and do not have keyboard, the only this it has is the keypad on the gront panel.
Motorolla L7 does not slide nor flip, it is flat phone that as all its function keys on the front panel. It does not have a keyboard either, it only has a keypad whivh is common to all phones.
Take care.
4 beeps but won't come on
4 beeps of equal lenght suggest that system timer is not working, you need to change cmos battery on your laptop. If you are game, that is how you change CMOS battery on your laptop:
1. Switch off computer, remove power cord and battery, turn computer "proper" side up, open and press power button to discharge
2. Open display in full (180 degree), there is small indent on hinge cover, close to hinge on right and left side, slide in little flat (screwdriver will do) and lift right side up, slide cover towards left and remove it, do not lift on both sides simultaneously!
3. Remove two small screws on the top of keyboard, lift keyboard slightly up and towards you, be aware that keys and tabs on keyboard are fragile and difficult to replace! Lift keyboard connector and slide the cable out. it is not really necessary to remove keyboard, but it easy to replace without keyboard being in the way.
4. Find coin battery, disconnect cable from socket by pulling it gently towards the battery. Remove cable from guides and battery from it's seat
5. Replace battery with exact same type, put it back into it's seat, guide wire through and connect it back to the board.
6. Re-connect keyboard cable, place front keyboard tabs into palm rest and screw back two back holding screws
7. slide in left side of hinge cover into place, press from left to right till it click in place.
8. Re-install battery and power cord, switch on computer, re-programe BIOS ito previous state.
This should solve your CMOS batery problem. Of course you can send your laptop to the technician but that will be no fun at all... ;-)
Qwerty key issues
try running a megnet over the back of the screen when you slide it open, it worked for mine
THE ZOOM SLIDE IS TOO SENSITIVE
1) Open your Logitech Software (SetPoint).
2) Press "My Keyboard" tab on the top of the screen and select the "Zoom Settings" tab on the left.
3) Drag the sliders to adjust the speed and acceleration of the zoom.
4) Click Apply to save your settings.
YBC (/\)
Keyboard not working
There is a guide that show you how to disassemble pantech phones, a service that repairs those phones is also available there.
I need to install a keyboard for a Dell Inspiron 1525. I need step by step directions
Before you begin, Follow these steps carefully;
  1. Shut Down to turn off your computer. Ensure that the computer is off and not in a power management mode. If you cannot shut down the computer using the operating system, press and hold the power button for 4 seconds.
  2. Disconnect your computer and all attached devices from their electrical outlets. Disconnect any telephone or network cables from the computer
  3. Remove any installed cards from the ExpressCard slot.
  4. To help prevent damage to the system board, you must remove the battery from the battery bay before you service the computer. to do this, Turn the computer over, Slide the battery release latch until they click into place. Slide the battery out of the battery bay.
  5. Turn the computer top-side up, open the display, and press the power button to ground the system board. Now you are ready to remove your Keyboard;
  6. Removing the Center Control Cover, Remove the two screws securing the center control cover from the battery bay,
  7. Turn the computer top side up, and open the display as far as it will open.
  8. Insert a plastic scribe into the indent to lift the center control cover on the right side and ease the center control cover up.
  9. Disconnect the cable from the media control buttons connector located underneath the center control cover. NOTICE: To avoid damage to the data cable connected to the system board, ensure that you do not pull hard when you are raising the center control cover. NOTICE: To avoid damage to the center control cover, do not lift the cover on both sides simultaneously.
  10. Remove the center control cover.
  11. Remove the two screws at the top of the keyboard. NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
  12. Lift the keyboard and hold it up and slightly forward to access to the media control buttons connector.
  13. Disconnect the media control buttons connector and remove the media control buttons cable.
  14. Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
  15. To disconnect the keyboard cable from the keyboard connector on the system board, rotate the keyboard connector latch toward the front of the computer.
  16. Slide the keyboard cable out of the keyboard connector.
  17. Replacing the Keyboard
    1. Slide the keyboard cable into the keyboard connector.
    2. Rotate the keyboard connector latch to secure the cable.
    3. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    4. Press on the right edge near the top to snap the keyboard into place.
    5. Replace the two screws on the top of the keyboard.
  18. Replacing the Center Control Cover
    1. Reconnect the media control buttons cable to the connector below the keyboard.
    2. Align the tabs along the bottom of the keyboard and slide them under the palm rest.
    3. Press on the right edge near the top to snap the keyboard into place.
    4. Replace the two screws on the top of the keyboard.
    5. Reconnect the media control buttons connector to the center control cover.
    6. Insert the left edge of the center control cover.
    7. Press from left to right until the cover snaps into place.
    8. In the battery bay, replace the two screws that secure the center control cover.
Desk drawer - slides open
my husband is having trouble installing a kitchen drawer slide--it keeps jumping off track--can anyone help??
Casing
The memory socket is located below and to the right of the keyboard. The panel is to the right of the mouse pad.
The keyboard needs to be removed. DO NOT REMOVE THE KEYBOARD CABLE! Remove the screw located in the middle lof the underside of the n610c. Slide the four tabs located on the top edge of the keyboard toward the space bar. The tabs are located to the right of the esc, the F4, the F8, and F12 key. Using a flat blade screwdriver gently lift the top edge of the keyboard, once it is lifted slide it toward the screen.
The panel covering the memory may require "gentle force" to remove.
DVD/CD-RW
1. At the back of the laptop remove the three screws on the support posts for the screen
2. Open the laptop fully and lift the plastic panel that has the power button.
3. Remove the 2 screws holding the keyboard in place
4. Carefully slide the keyboard towards the monitor and lift.
5. To the left of the keyboard ribbon cable is the screw hidden under the keypad.
6. Remove, slide out optical drive, reassemble.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
