Question about Sony KP-61HS10 61" Rear Projection Television
My display is arched on the top and bottom of display on my sony kp61hs10. Wanted to know a solution to fix this issue.
  • 10,594 Answers
Convergence output ICs in your tv got defective and causing arched on top/bottom of screen.
Convergence output ICs will be replaced to fix tv problem. There is Convergence Repair Kit available along with photo instructions to fix tv problem and you can attempt to repair tv if you have little experience for that to understand those instructions. Or local tv repair shop will help you to fix the tv problem.
Posted on Jul 19, 2010
SOURCE:
Words at top and bottom of the screen on my Sony rear projection tv are arched. Also some ghosting of images?
Sounds like a convergence problem--see attached pictures--if so let me know model number and I will offer advice.
May 30, 2012 | Sony Televison & Video
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Turning closed caption on Sony kp61hs10
Your power source seems to be the problem, you will need to replace that part.
Jul 18, 2010 | Sony KP-61HS10 61" Rear Projection...
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
Arch in color on Panasonic
hello sound like convergance chips also check resistors and capacitors hope you get it fixed
shaun
Jul 31, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection.
Put tv in standby then press above said buttons. You will be in service mode.
Be Care Full while in Service Mode data handling.
Oct 03, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony KP61HS10 Convergence issue
u may purchase service manuals here/
www.servicemanuals.net
Jan 09, 2008 | Sony KP-61HS10 61" Rear Projection...
RED arched lines
http://esupport.sony.com/perl/news-item.pl?mdl=KP51HW40&news_id=24
Nov 17, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony FD Trinitron WEGA kv32fs120 32" picture too big/vertical arch...
Sounds like you have a problem with the high voltage regulation or the power supply. This condition is called "blooming" Stargazer
Aug 18, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
287 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
