When the call is active, select option> you will get the option for recording the call conversation. And the call will be saved under voice record folder
Try this. When you make or receive a call, during the call click option button in your screen, choose record conversation. See if this work, by exploring your voice digital folder and search the recorded call.
It is possible to record your phone conversations. Sounds like you are trying to activate a voice recorder while you are talking on the phone (this would only record one side of the conversation anyway - yours). Here is a website all about <a href="http://www.recordphoneconversation.com>recording phone calls </a>
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
Using the OPTIONS menu while in a call, you can go all the way to MY SOUNDS menu. (Normally from there you can choose RECORD NEW) but if you are on a call it says NOT AVAILABLE DURING CALL... so you can't do it using the standard LG setup. Sorry.
if you cant hear caller voice. do one thing go to gallery and go to voice recorder and record some voice then save that then go to media and play recorded sound if its working means your loud speaker is working but not ear peic means (ear speaker) not working. so then you need to change ear speaker.you can do your self just watch video on online.
Settings: In Settings dialog you can set the following options for Best Answering Machine:
* Greetings - allows setting up the greetings played on pick-up; * Active in profiles - defines in which profiles the application will pick-up the phone and record messages; * Storage - allows selecting on which disk the records will be saved; * Pick up after - sets the time after which the call will be answered; * Record time - maximum amount of time the message is being recorded; * Format - message file format (amr,wav); * Icon - configures the visibility of the icon displaying application activity and presence of new messages; depending on this parameter, can be shown in standby screen only (Phone application) or in any application; * Play volume - play volume for the greeting; * Records lifetime - automatically removes old messages;
Messages: In this view you can listen to new and old messages, delete unnecessary messages, send the recorded messages and call the person directly from this view.
During the call:
When Answering Machine is processing an incoming call, you will see a dialog showing the application's progress with the ability to stop it:
* Answer - when this command is chosen during a call, it stops greeting playback or message record and you can continue talking to the caller; * Hang up - stops greeting playback or message recording and terminates the call; hope this will be helpful...
to record voice memos, press the menu button, and select OFFICE->RECORDER. To record a conversation, choose RECORDER during a voice call. Both parties will hear a beep every 5 seconds while call is being recorded.
This is a phone system phone. If you can record conversations it would be a feature of your voice mail on the system (the phone itself cannot do this). If it all worked, you should have the recording in your voice mail box. It may be in with recorded messages or there could be a separate location. Example: Press 1 to hear your messages, press 2 to hear your recordings, press 3 to change your password, etc...
Hi, I'm having problems with the telephone recording using a digital cordless phone. Once the hanset is picked and conversation is going on, the unit does not record???
