How to make dlink wireless connection as secured connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
You can enable WEP, WPA, WPA2 on your router.
Open a Browser type 192.168.0.1 to access
Username is admin and password leave it blank.
Click on Wireless
Security Mode: Change it to WEP, WPA or WPA2
Change the Network key, it serves the password on your network
Heres the difference bet WEP,WPA WPA2
Wired Equivalent Privacy (WEP) is the original wireless encryption standard. It is a method of encrypting data for wireless communication that provides the same level of privacy as a wired network. WEP is not as secure as Wi-Fi Protected Access (WPA) encryption. To gain access to a WEP network, you must know the key. The key is a string of characters that you create. When using WEP, you must determine the level of encryption. The type of encryption determines the key length. A default key (also known as a pass phrase or network key) is selected for use on the network, and is located in brackets on the bottom of all 2Wire devices.
64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
You can define the keys by entering a string in HEX (hexadecimal - using characters 0-9, A-F) or ASCII (American Standard Code for Information Interchange - alphanumeric characters) format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
WPA-Personal
This option uses WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client. For example,
Wireless Networking technology enables ubiquitous communication.
WPA2
This option provides stronger data protection and network access control. It provides enterprise and consumer Wi-Fi users with a high level of assurance that only authorized users can access their wireless networks. Based on the IEEE 802.11i standard, WPA2 provides government-grade security by implementing the National Institute of Standards and Technology (NIST) FIPS 140-2 compliant AES encryption algorithm and 802.1x-based authentication.
There are two versions of WPA2: WPA2-Personal and WPA2-Enterprise. WPA2-Personal protects unauthorized network access by utilizing a setup password. WPA2-Enterprise verifies network users through a server. WPA2 is backward compatible with WPA.
hope it helps
SOURCE: Had a wireless network. Today Time Warner had fire
HI! to secure the dlink wireless network, u need to access the setup page of the router, pull up a browser and type in at the url:192.168.0.1 and it will ask the username and password, by default the username is admin and password, just leave it blank and it will show the setup page, on the left side select on wireless settings and manual settings, you can select any option here on what type of security u will set. once setting is done u have to save the settings.. once done u have to connect ur wireless computer to the secured wireless network that u create it will ask the password and connect
SOURCE: unsecured connection
there are usually two ways to do this. one, your router should have came with a disk. if you run that disk it should walk you through step by step. if no disk, try typing 192.168.1.1 into the address bar. this should take you into the router diagnostics. in this, you should see some tabs about setting up the wireless settings. if neither one of these work, the best bet is probably calling dlink tech support for help.
SOURCE: does not save wireless security settings
Encrypting the network blocks any unauthorized computer from accessing
the network and using its broadband connection. To enable WEP on the
router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2.
When prompted for a username and password type “admin” on password,
unless you have previously changed the password of the router, and hit
OK. This will bring you to the Setup page of the router.
3.
Depending on the firmware of the router. Click on the WEP Key Settings
button. Or you can click the Wireless tab and select Wireless Security.
Or you can click the Security Tab and select Wireless.
4. From the
WEP/Security Settings window, you may enable 64 or 128 bit WEP then
enter your Password on the Passphrase field and click on Generate. Make
sure to copy the characters on Key 1-4 on a piece of paper before you
hit APPLY. You will be needing this once you enable WEP on the wireless
PC’s. Also take note that if you enable 64 or 128 bit on the router,
this should be the same WEP level that you will enable on the wireless
cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1.
Go to start>Control Panel>Network Connections>Right click on
the Wireless connection then click on Properties>Click on the
Wireless Networks Tab
2. From the Wireless Network Connection
properties window, under the Preferred network click on Add then type
your SSID on the SSID field and check the box for Data Encryption then
then uncheck “The Key is provided for me Automatically”
3. Type
your WEP Keys on both the Network Key and Confirm Network Key field.
(This set of characters should be identical to the WEP Keys Settings on
the router. For 64-bit WEP you should have 10 characters, for 128-bit
you should type in 26 characters.) Then hit OK and then OK again.
4.
After hitting OK a pop-up should appear on the lower right hand side
saying “Connected”. Try pointing your mouse arrow on the lower double
monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make
sure that the WLAN utility of the Linksys adapter is already is
installed. If not, you may follow follow the procedures below for
"Installing the Linksys WLAN Utility"
1. Click on Start then
Programs, then click on anything that says something about the Linksys
Wireless Adapter. On the menu, select either WLAN Utility or Wireless
Configuration Utility
2. On the lower right-hand side of your
screen, double click on the Linksys Icon. This will bring up the WLAN
Configuration Utility.
3. Click on the Profiles Tab. Make sure that
the SSID that is set to default is your routers SSID. Highlight Default
then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6.
Type your WEP Keys. This set of characters should be identical to the
WEP Keys Settings on the router. For 64-bit WEP you should have 10
characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
SOURCE: I am not able to connect my iphone to my home wifi
No, just like when you set up a wireless connection for the first time with a home network, you need to input the network key. As long as you have the key handy, it should work!! For example, when I connect my iPhone to home network, I see my network name "553c" and I "touch" that and it asks what kind of security it has (unless this has changed, my iPhone is 1st generation) so I pick WEP (you will pick WPA of course : ) )and then it prompts for the network key. Hope this helps!!
