Toshiba Satellite M45-S165 Notebook Logo
Posted on Jul 19, 2010
I need sound driver for toshiba satellite m45-s165 for window xp
5 Related Answers
Anonymous
  • 42 Answers
  • Posted on Apr 14, 2008
SOURCE: toshiba m45 s165 - installing hard drive
http://www.retrevo.com/s/Toshiba-M45-S165-Laptops-manual/id/614bh526/t/2/
Above is the website for your laptop's manual. It should give reference information for hard drive installation.
Christian Fernandez
  • 135 Answers
  • Posted on Sep 17, 2008
SOURCE: how to use s-video on toshiba satellite m45-s165?
Detailed instructions here:
http://tinyurl.com/5kd7s8
Hope this helps.
Anonymous
  • Posted on May 22, 2009
SOURCE: I need all the driver for toshiba satellite A 135 -S2386 windows XP
i need xp drivers for A135-s2386
Anonymous
  • 73 Answers
  • Posted on Jun 17, 2009
SOURCE: Toshiba Satellite A135 S4527 PC windows xp service pack 3 drivers
Try uninstalling sp3 from add or remove programmes in control panel..because some of the drivers are not compatible with sp3
Anonymous
  • 58 Answers
  • Posted on Jul 26, 2009
SOURCE: Replaced hard drive in Toshiba Satellite M45-S165,
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
36
In need of restoring to factory settings, (Toshiba Satellite M45). Held down zero, powered on, no beeps occur. The recovery utility never appears. Not listed in All Programs for Hard Disk Utility nor in...
It appears the recovery partition has been removed from your hard disk. You need to obtain a Recovery CD from Toshiba.
OR
If you have a Windows XP Home installation CD then you can use it to reinstall Windows on your Toshiba and the product installation code will be on the Windows label on the bottom of your laptop.
You can download thedevice drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsphttp://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
2helpful
3answers
Can windows 7 run on toshina satellite m45-s165
Hi, to have a good answer please download from Microsoft webpage the program that let you check if your hardware is good for Windows 7.
You can download it here
http://windows.microsoft.com/en-US/windows/downloads/upgrade-advisor
I want to connect my Cassatt Tape Recorder to Toshiba Satellite M45-S165 Laptop and record data by using Audacity Software. Recommend the connection cable
I have never used that programme but expect it uses the sound card as an interface. If it does, the manual will tell you, you will need a Phono lead with 3.5mm jack plug on one end.
Hope that helps.
Format problems
change the boot order in the bios and set the it so the cd is read first
1helpful
M45 s165 power light on nothing else
Please hear for a beep sound if you hear the beep sound then the rams may be defective otherwise the mother board seems to be defective.
Window7 drivers for vga-vidro on toshiba satellite m45s165
Sorry, your system doesn't support Windows 7.
you might be able to install windows 7 in your notebook but Toshiba doesn't release any drivers for your notebook for Windows 7.
If they have release drivers for atleast windows Vista then it might have work out fine with windows 7 as 90% of the drivers meant for windows Vista work fine with Windows 7. only webcam drivers usually have the problems.
Need sound card driver compatible with vista
http://drivers.softpedia.com/ u can download driver from this link
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
