Inverter Pure Sine Wave 1500w Inverter Logo
Posted on Jul 19, 2010
Anything that runs on the battery will not work
Was fine, heard buzzing, turned light on would not come on tried again came on then was gone
[email protected]
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 16, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
76
Points
Ur battery exp.(if it is 3 or 4 year old)
ur inverter is over load
Won't turn over... just makes a clicking sound... and a wierd humming sound.
Try cleaning your terminals at the battery, even if not corroded. In my years as an alarm/radio installer I have come across this problem constantly, especially on GM vehicles.
I JUST PUT BATTERIES IN THE REMOTE AND IT WILL NOT RECIEVE THE ORDER FROM THE RMOTE WHAT SHOULD I DO THE T.V. BRAND IS ESA
To troubleshoot the remote control problem, follow this step. 1. Check the battery (new if possible) 2. Get a ordinary radio then scan the radio to no signal frequency...just a buzz song will be okay. 3. Try to point your remote control in front of your radio, then press any keys (numbers or anything) 4. If you heard some sound to the radio while pressing the keys 4.a Your remote control is working fine. 5. If you did not heard anything while pressing the keys 5.a Your remote control is not working. You need to replace it or just buy a universal remote control (cheapest way to do).
Thanks. Hope this helps.
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
1helpful
2answers
NAVIGON 7100 WON'T TURN ON
your battery is gone requires new one.
2answers
Van will not start,just goes "chuk, chuk,chuk," when I turn key
you need to check for a bad conection at the battery cables. both ends Check the wires on the starter. clean the battery post. Give the battery a good charge you will be back on the road. hope this helps PS You can get the battery charged and tested free at auto-zone.
2answers
99 Dodge Neon sohc. Drove to work just fine came
How old is the battery? Clean the connections, charge the battery. Try starting it. Get the battery tested at Autozone or some place like that.
Car won't start, no lights in panel turn on, engine doesn't make clicking noise nor does it crank
hi..
its a simple thing....The battery has run down flat or the starter has gone bad. check the two.... ur problem is solved.. rate me fixya
Is it my battery?
well this is what you should try ,,jump the car get it running
then when its warmed up take the positive lead of the battery
if the car stops the alternator is gone (thats what charges the battery) if the car runs its fine
and if u have put another new battery in it and the alternator is fine look for any broken wires earths or positives that could be making it drain so quick
and make sure your battery levels are full
hope this helps
Top Inverter Electronics - Others Experts
Ngoro
john h
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
