Car Audio & Video Logo
Posted on Jul 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have MR-4. Radio works but it's not pulling CDs. Mode button not working.
Anonymous
Level 3:
President:
  • Master 567 Answers
  • Posted on Jul 19, 2010
Anonymous
Master
Level 3:
President:
Answers
567
Questions
Helped
109751
Points
2033
Hi the CD drive is going bad thats the reason why its not pulling the CD, you should get the CD drive replace.
  • 1 more comment
  • diamond1111 Jul 19, 2010
    Would that be cost effective OR should I just replace the whole thing.
    ???? Would that be cost effective OR should I just buy a whole new system ?????
  • Anonymous Jul 19, 2010
    Its cost effective if you buy a new one.
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
I am not able to switch to cd player in my 2005 grand cherokee radio
is bad, the CD drive is bad.
you have choices.
1: check all fuses.
2: replace it. $$$$$$
3: get it fixed $$$$$$$$$$$$$$ ($50/hr x4 ? and parts, nah....)
4: dismantle it, and unjam it , clean it, make sure no broken CDs in sided or labels fell off inside, or other alien objects inside, blow it out.(canned air) (silent prayer?)
4: upgrade to a head end with USB port and run USB mem stick with 1000 of songs off a stick the sizes of a Chiclet gum.
id go with #4, upgrades are a big win..
1helpful
I made a mistake and hit the sync button on my radio..and now theres a white screen with across in the corner and i cant utilize the screen or cds or dvds..only the bluetooth works...ive removed the car...
You probably have on your car stereo either a single push button that you press to select the audio source (Radio/CD/DVD/Bluetooth) or 4 separate buttons labeled: Radio, DVD, CD, Bluetooth, respectively. Because a sync operation can refer only to a Bluetooth audio source (phone, tablet), your stereo is in now in the source mode for a Bluetooth audio source. Find the button or buttons for the selecting the audio source and select Radio or CD or DVD (you are already on Bluetooth).
2003 monte carlo, radio plays, but none of the buttons work, no display
All you can do is remove the radio and have it repaired by a local approved GM radio repair shop.
My motorola has an emergency alert button on top, when pressed and held it sounds an alarm on all other radios near it. we pushed it to test and it works well and is a cool feature. however, the call tone...
Your radio may be functioning normally for the emergency alert. Here is an excerpt from the user guide:
Emergency Alert Mode
The Emergency Alert feature can be used to signal members in your
group of your need for urgent help. MR series radios will operate in an
automatic "hands-free" emergency control mode for a total of 30
seconds after activating the Emergency Alert. MR series radios in your
group will automatically advance the speaker volume to the maximum
setting and sound a warbling alert tone for 8 seconds. The alert tone is
emitted from your own radio speaker and the receiving radios in your
group. After the 8 second alert, any spoken words or incidental sounds at
your end will be transmitted to the group for 22 seconds. For the 30
second duration of Emergency Alert mode, MR series radio controls and
buttons will be locked to maximize reception of the emergency message.
1. Press and hold the Emergency Alert button for 3 seconds.
2. Release the button after the LED Indicator glows red and the alert tone
begins to sound. There is no need to continue to hold the Emergency
Alert button or use PTT for your message to be transmitted.
3. After the alert tone ends you may speak into the microphone. Your
voice or incidental sounds will be transmitted. The LED indicator will
continue to glow for the duration of the 22 second period.
4. After 30 seconds your radio speaker will emit a Talk Confirmation
Tone and the LED Indicator will extinguish. Operation then returns to
normal two-way mode.
Note: All Motorola Talkabout EM, MJ, and MR series radios are fully
compatible with the Emergency Alert feature. Radios other than EM, MJ,
MR series can receive the emergency alert signal, but will not respond
with adjusted volume settings, locked controls, or a warbling alert tone.
Users of other radio models set to the same channel and Interference
Eliminator Code will hear a steady tone for 8 seconds followed by the
voice transmission for 22 seconds.
Warning: The Emergency Alert feature should only be used in the event
of an actual emergency. Motorola is not responsible if there is no
response to the emergency alert from the receiving group.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
4helpful
2answers
2004 NISSAN SENTRA . THE VOLUME OF THE RADIO STOPPED WORKING. THE KNOB WORKS, THE BUTTONS FOR DIFFERENT RADIO STATIONS WORK. THERE IS JUST NO VOLUME.
same this happned to me in my 2006 sentra. the volume for the radio is gone. i can tune, its just barely audible/ quiet. weirdly though it sounds perfect when playing CDs. i almost thought maybe it got switched in to mute mode or something. did you figure out your problem?
1helpful
JBL MR-17.2 not recognizing Sirius satellite receiver.
I have the exact same issue. I have swapped with two identical MR17.2 radios and swapped out the sirius receiver. No change. I even bought a remote thinking I had to have a remote installed to get it to work...still no diff. Have you ever found a solution?
CD player won't play or eject CDs
I hope you're in the 4 year 50,000 miles warranty.
the cd player will probably have to be changed. you can try pulling the fuse to the radio. maybe it will reset and work properly. the only downside is it may have a security code that needs to be input to work again. sometimes they write it on a card or in the owners manual.
good luck.
TH-79A amateur radio
TH-79A Kenwood HT and with the power off, hold down the MR button and the PTT switch, and while holding both of these turn on the power. The HT will come up in the remote control mode with the display indication "RC" on one band and the normal display on the other band.
To get the HT out of the "RC" mode just repeat the MR+PTT+Poweron sequence
2helpful
3answers
Radio in SAFE mode
Hey.. i just had the same thing happen... bought a 1994 Jetta.. radio in safe mode... so i went online and found out.. hold scan mode and the arrows after your preset station button.. then after like 3 secs or so you'll see " 000" on the display.. use the preset buttons.. 1,2,3, and 4 to change the display to enter your code :D if you lost your code go to VW dealer and pull radio out and see service center .. carry VIN code in as well and they can look up your code.. takes like 5 mins and is FREE,,, man i love that word :D
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
John
John
 Mikey
Mikey
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
