Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
You can get replacement Vizio remotes from Walmart, $10. As far as the pedestal, I can't locate one either. I would suggest checking Ebay frequently. I recycle LCD sets and come across rare pedestals. If you would like, visit our website, click on Contact US and leave your contact info. I will put you down on our Wish List and contact you if we get the pedestal in stock.
The damage actually occurred on the LCD (liquid crystal display) itself, not on the screen. Therefore, when the tv is switched off, no damage is visible. What happens is that when it is turned on, the liquid crystals "leak" because the display is broken. This is why you can see lines and a small dent.
Depending on the tv, replacement LCD panels may be sold separately, though chances are that it would cost less to simply buy a new tv.
Thanks for your post, and I wish you the best of luck!
Sincerely,
Der Strom
I had a similar problem with my Vizio Model VX37L HDTV and replaced the main board myself for $160.00 which I purchased new on Ebay at ShopJimmy.com. The symptoms all of sudden started by the screen going blank except for a rectangular banner across the top that resembled a UPC code only garbled. No sound. I actually had to pull the power cord to turn off the TV. I was able to turn on the set normally but the TV menus did not come up. Since the TV was 19 months old and no extended warranty I checked with Vizio support and Sam's Club but no extended warranty=no luck. I did have an estimate for repair for $900 from a company Vizio recommended but a new one goes for less now. About 42 screws and a half a dozen pin connectors I replaced the main board. The set is working again better than ever. I don't know if I call my self fortunate or not since I did have a problem after only 19 months.
i have this tv it has screen broging
i want fix screen but what i do ?
my mail is [email protected] VIZIO TV MODEL # AND ALL DATA
MODEL NO VIZIOVX32L
HDTV 10A 100-240V-1.5A 60/50HZ
SERIAL NO LSSABBH 1919067
MFG. DATE MY 2007
poless send me enformation
