Vm9512 screen problem: you can slide the screen out by hand somewhat, and at a point if you press open it will slide about half a inch. But it will not flip up no matter what, not by hand or the button. Does anyone know if this is a problem with the motor or radio. How can this get fixed?
Try removing all the toner carts and remove the drum unit from the printer. Using the upholstery tool on your home vacuum cleaner, clean all over the drum unit being careful not to directly touch the drum surfaces (they scratch very easily causing permanent marks to print) also vacuum out the inside of the printer. It is likely that dust is preventing correct charge build on the drum. Also make sure the green slide tabs are placed back at the home position at the side of the drum unit. Re-assemble and test.
try sliding the door by hand to the right. If you can slide if, lift up on the left side while sliding it all the way to the right and the doot should slide off. Then try sliding it back on. One of the door switches is probably out of place and just needs to be realigned.
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal 2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m). 3. Push and hold (at least five seconds) the center crown 4. Watch will beep and word (SYNCHRO) will appear in the display. 5. Use the top + button to line up the minute hand right on the 12. 6. Use the bottom – button to line up the hour hand right on the 12. 7. When finished, press crown and you will go back to time.
Well, the screen issue you are describing with the ipod sounds like the ipod's clickwheel is malfunctioning. A malfunctioning clickwheel will allow you to reset the ipod, but not actually make selections. At this point, you can either replace the clickwheel or if your ipod is under warranty, take it in for service.
*I am assuming that you are actually resetting the ipod correctly. For example, when reset, after bootup, the ipod will ask you to select a language. If you are not getting to that screen when you "reset" it, then you are likely doing it incorrectly. If that is the case, I'd suggest checking your HOLD button before suspecting a bad clickwheel. Since there are slightly different procedures for resetting ipods depending on model and generation, I'd suggest doing a search online (or going to Apple's website) for instructions on how to reset your particular model. Note that ipod generation can be easily found printed on the back case of the ipod.
There is a delay as it downloads and therefore you scroll and wait for the page to download. Occasionally I scroll back and forth to the first page until I get the next page.
turn on the player, start the radio option, go into the setup menu, tap the language tab, ON THE REMOTE press "stop, stop, 5,4,3,2,1" This will bring up the secret menu, you do not need to connect the pink wire
with the remote:
press set up button
scroll to highlight language
enter 5,4,3,2,1,0
you will now be in a secret menu
turn on brake bypass
and exit
done
