JVC Everio GZ-MG130 Camcorder Logo
Posted on Jul 19, 2010
How do you transfer video from internal memory to sd card
2 Related Answers
Anonymous
  • 72 Answers
  • Posted on Aug 07, 2009
SOURCE: Transfering video to SD Card
if your camera takes an sd card their should be a save to memory card setting in the menu of the device if that does not work you could transfer them to your pc then drag and drop them on your sd card
Anonymous
  • 166 Answers
  • Posted on Feb 27, 2010
SOURCE: I cant seem to transfer videos from my harddrive JVC Everio
quick thought... has to be formated corectly.. did you format it on the camcorder?
1helpful
3answers
How do I transfer pictures from the internal storage to a sd card?
hi rednpat986.
this is all i could find,if this does not work go to the link at the bottom.
How to transfer photos from camera internal memory to SD card? Follow these steps:
  1. Insert a memory card into your camera.
  2. Turn on your camera.
  3. On the camera, press the Review button then the Menu button.
  4. On the Setup tab in the menu (your menu tabs might be named differently), select Image Storage.
  5. Select Internal Memory.
More items...
Transfer pictures from internal memory to a card - Kodak Support
camera How do transfer pictures from the internal storage to sd card...
Nov 05, 2017 • Cameras
1helpful
1helpful
Cannot transfer applications from internal memory to SD card
You can install an app called App 2 SD.
Then you can select the app you want to move to the SD memory.
8helpful
Copy between internal memory and SD card on olympus TG-1
Use the "Backup" command in the settings-1 menu. See page 45 of this manual.
How to transfer pictures from camera to sd card
The pictures that are stored on your camera memory cannot be transferred to the SD Memory Card. They must be downloaded to your computer first and then transferred via a card reader, if you intend to get them to the SD Memory Card. The two memory areas, internal and SD memory work separate of each other and the camera only operates from one. IF the system detect SD Memory than that is where the images are saved, if not, they automatically go to the internal memory.
Here it the manual for your camera:
http://www.pentaximaging.com/files/manual/E30_E.pdf
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
1helpful
Hi, i have some photos on my internal memory and need to put them on an sd card because the connection with usb is faulty. As soon as i put an sd card in camera i cant see internal memory images. Is...
There should be an internal transfer from memory to SD card on most camera but not all look under the main menu for the memory card where it tells you to format card and create folders it there should be a COPY option.
8helpful
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
