Wii fit balance board keeps saying please step off me and press a to continue. I re-synked the board as well as ran the test on the system that stated it was running properly. Any other suggestions?
When you power on the wii fit board, does the light flash continuously? If so, you will need to sync your board with your wii again. You can get instructions on how to do so here: http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp
iv got the same problem too, iv resync it and nothing, wiped the wii clean and started again and nothing (mine went down just b 4 xmas and 'santa' got my boy the wii fit plus and he ant been able 2 play it yep) PLEASE PLEASE PLEASE some1 help
Insert a Wii Balance Board compatible game disc in the Wii console.
Use
the Wii Remote to select the Disc Channel from the Wii Menu, then
select "Start" to begin the game. Press the A Button to bypass the
wrist strap screen.
Open the small SD Card slot cover on the front of the Wii console.
Remove the Battery Cover on the bottom of the Wii Balance Board.
Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
The blue light will stop blinking and stay on steady once the syncronization is complete.
Fore more detailed information (including pictures) on how to sync the Wii Balance Board, click here.
If you are still unable to sync your Wii Balance Board, please call 1-800-255-3700 so that they may assist you further.
I managed to get my board working by, removing the covers from the feet sensors then placing the board upside down on the floor, then gently pulling on one foot sensor and pressing a, i continued until i found the one with the problem,
the solution i found was if you loosen the screw connecting the plate to the sensor very slightly the board will the calibrate and function correctly,
my board is still working without problems, hope this helps
