Sounds like you have a bad swith in the drivers side handle pull out switch board and check for power on those only when turning in down and on position should see power if not bad switch never heard of two motors going bad at the same time
Bad window motors. Before changing motors, check to see if front and rear windows operate on separate fuses. If all four are on the same fuse, then the motors are probably bad.
SOURCE: power windows stopped working
If all the windows stopped working at the same time, then its probably just a blown fuse. The fuse box is located on the left side instrument panel.
Good luck
SOURCE: 1999 Dodge Durango driver side window does not roll up nor down.
Remove the door panel and find the window motor Unplug it and using a separate car battery run cables directly to the window motor When you switch the polarity the motor will either bring the window up or down or if noting happened change the window motor and window regulator assembly.
