Troy Bilt Tb70ss Gas Trimmer Logo
Posted on Jul 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Weed wacker wont start
I have a troy-bilt weed wacker that wont start. It sounds like it wants to kick on but dosent
Anonymous
Level 2:
Sergeant:
  • Expert 200 Answers
  • Posted on Jul 21, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
200
Questions
0
Helped
76363
Points
513
Try a new spark plug or checka and see if it is getting fuel
1helpful
I have a Troy-Bilt Super Bronco 4-cycle weed wacker motor runs great but the trimmer head does not spin can anybody tell me how to fix it
does engine bogg down if so try clearing any grass /debris around shaft --- greasing shaft --check for damage shaft or head
On troy bilt weed wacker how replace pull cord
Take off the housing I'll out the turn the spring loaded husing to full extension put a screwdriver to hold it in place replace the cord pull out the screwdriver and replace housing
Jul 28, 2018 • Troy Garden
My troy bilt weed wacker started to make a rattling noise from the engine a couple of weeks ago. Now the head has stopped turning, it appears that the drive shaft is not turning.
sounds like something came look in the clutch assembly. you have to remove the shaft from the power head and take a look inside the cover.
Rope on my troy bilt weed wacker is stuck want pull
It sounds like the engine seized up which means the piston is stuck to the cylinder wall. This could be do to a poor fuel to oil mixture, not enough oil mixed with the gasoline. They are not worth repairing
Mar 10, 2011 • Garden
Weed wacker runs then quits and won't start for hours
Sounds as if the issue is related to heat. Possible ignition failure when hot. (I see that alot in my shop.) If the unit is new take it to an AUTHORIZED repair shop and it should cost you nothing. Locate your nearest repair shop HERE.
Hope this is helpful,
Dolf-
2helpful
2answers
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Top Troy Garden Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Troy Garden Expert? Answer questions, earn points and help others
