Logitech X-530 Computer Speakers Logo
Posted on Jul 18, 2010
5.1 speakers connected to a dvd player ?
I'm having trouble connecting my logitec speakers to my dvd player ?
This is driving me crazy. What cable do i need to go to the dvd player from the magick box that connects the speakers you have the pink green and black on one side, then red & white on the other,what do i need for the other side and where does it go to on the dvd player at the back ?Please e-mail me ?
[email protected]
Pictures of the leads would be a big help plus the name of them also.
Many thanks.
Kind regards
paul powers
Anonymous
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Dec 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
6943
Points
81
You need an RCA - RCA cable,that means that you need a cable with RCA at both ends. At the back of the dvd player,look for sound section (RCA jack) In the sound section look for "right" and "left" connect the two RCA jacks in there and you`re done.
------- If you don`t know how an RCA jack looks like,see this image
  • sharon marx
    sharon marx Mar 08, 2015
    The only wire coming from speakers is green. That's where the problem is. I understand about rca cable. It's the green cable from speakers that I don't know where to put it.
Hello!!! Thanks for letting me ask these nagging questions. I bought a set of six JBL Home Theater Speakers.I did manage to have them connected and working. But I face a dilemma: How do I connect my...
You want to connect the JBL's to the yamaha using standard speaker wire. Get a few HDMI cables and run one from the blu ray to the yamaha and from the yamaha to the tv. To use the JBL's for watching tv, get an optical cable or coaxial cable (either will work) and connect that from the tv to the yamaha and you are all set.
2answers
I have a 32 "
Check how you have the satellite cabled. I suspect that you have the video from the satellite to the TV but the audio cable going directly to the stereo. You probably have the DVD audio and video going directly to the TV. (I'm assuming you have the 32LA30rq and not the 32LA30rqd which has a built-in DVD and thus has the audio connection inside the TV.)
Since you don't mention which connection you are using for the DVD player and for the satellite, I will just mention the basics. If your DVD player is connected to one of the HDMI ports, that cable carries audio and video between the TV and the DVD player.
Devices that use component video cables use two separate cables. One cable with two sets of three RCA plugs carry the video; a second cable carries audio with 2 RCA plugs on each end. When you connect these, you do not have to connect the audio to the TV. (Similarly, a composite video connection can be modified for one line with the video signal going to the TV and the audio cable going to a speaker system.)
If my solution is correct, you may want to rearrange things. You can connect the satellite audio out to the TV audio in at the same location as you have the satellite video in. Then connect the TV's audio out (to the right of the component 2 in and above the coax audio out) to the stereo. Then switch the TV speakers off to use the stereo - Menu > Sound > Other Settings > Speaker On/Off. Then both devices will play either at the TV speakers or the stereo depending on the state of the TV speaker setting.
The manual is available here: http://tv.rca.com/product/manualdown.asp?modelnum=32LA30RQ .
I hope this helps.
2answers
Replace speaker wire to cable jack?
No, Please do not try that it is not the right approach and it can also damage you DVD player.
3helpful
Connect Creative 5.1 A500 speaker system to Phillips DVD 3256
Just buy two connectors(shown above). Its having two holes upside.
1. Connect the connector to one hole of the other.
2. Connect the audio cable to the dvd.
3. Then connect the connectors to the other side of the audio cable.
4. Lastly, connect the three stereo output cables of the Creative speakers to the three holes of the connector simultaneously.
I have tried this at home with my Creative Inspire M5300 speakers and philips dvd. All the five speakers are working.
Rovan C
2helpful
Creative Inspire 5200 speakers connecting to DVD player.
These are computer speakers, they will not work for a dvd player... Your dvd player has an rca/collex (SP) cable while your speakers have a 2.5 headphone style jack
Rear speakers
Well,i will be the judge of that.Please tell me how do you have your system hook up?Be details...ex. TV connected to receiver with HDMI cable..DVD player connected to receiver...
What component that you are having trouble with the rear speakers?EX. dvd player?Directv box?Both?
solutiondoct
The speakers shut off in the middle of a song
try different input sources(dvd-cd player-vcr)----if you get same result from all check your speakers cables and speakers itself start with cables and then speakers-if certain media source make the trouble check its connection cables to the receiver.--and then the media itself.
2answers
Cannot hear audio when connect dvd player to TV using analog audio cable
i think you need to get an Optical Digital Audio Cable and connect it to the tv and speakers then it should work
Connecting to my DVD player
If you are going to connect your DVD player to your TV you may use an RCA cable. Or you can read your manuals (for DVD player and TV) for specification of what type of cable is compatible to your system. Or you can look to your DVD player's and TV's input/output plugs directly to see.
P.S. If it helps you pls. rate me.
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
