SOURCE: Ford expedition stereo is dead...won't power up
try disconnecting power to the radio and see if it resets itself.
SOURCE: remove a stock radio from
If you want to remove a stock radio from a 2009 ford E150,then all that you need to do is - Step 1: Use the DTRT in a gentletwisting motion to remove the four (4) retainer clips securing kick panel belowthe steering column. Step 2: Again, place the DTRT inbetween the dash molding and the instrument/radio bezel (the bezel is onecomplete piece that includes the instrument cluster as well as the radio andclimate control) and gently twist the tool around the bezel releasing a seriesof retainer clips. Step 3: Pull the bezel out just farenough to gain access to the two 7mm bolts securing each side of the radio. Now as you open those bolts you canremove the radio.
