Their is most likely a problem with the pixels in your display. the reason why it dose this is that after the television warms up (about half and hour) the pixels adjust and start to work properly the only fix would be to replace the entire screen
You can increase the size of text by pressing control + or - buttons press control button first. Also there is zoom in the tools section and also you can increase the size of text in the control panel or the web page under tools sections of most browsers. If we new the browser or what you text is small in or even if it was small every where you can change the resolution size of your Windows. Win 7 you can incease text by going to control panel click on display once there go to where it says increase your text size. Not sure what your operating system is either. So assuming it is Win 7 I hope that this assists you. John
the integeral pixel of the screen have got damaged or there is a problem with your display screen's signal {video} cable go to a authorised service centre as you yourself can't set it right.also i would recommend not to go to any computer hardware technician as in cases of laptop untrained/un authorised company personals can damage your laptop
For lost pixels on the phone's LCD, it needs an LCD replacement. Most phone manufacturer, they just replace the phone itself instead of replacing the LCD on your wireless phone.
2 of my 3 have done the same thing. It seemed to have happened after our power went out, although they werer all plugged into surge protectors. Now over time since thne they barely have any display at ALL. Cheap junk, say I.
It seems the problem with display as well as to the charging unit. Display problem can be repaired only br replacing the display. And for your set, its not worth to get the display replaced. You can get the handset to your near service man to check whether the power charging unit works well.
ur display memory is corrupted. normally it is a shared memory or a part of the main memory unless u r using the graphics card.
try take out the RAM, clean it and put it back and switch on.
if not helped this, try with a good RAM.
good luck
Please don't forget to rate or accept the solution
I have had a couple of these systems over the years. When I've been searching on the internet to buy the second one, I found what you are experiencing is a pretty common problem. I bought the second unit for a second home and it was advertised as having some of the pixels missing on the display. when I received it, all of the pixels were present!! However, over time, they are slowly disappearing. I think this must have been a component or design flaw in this particular model. Today, I found the original system that has been off and stored for a couple of years. When I put it away, the display seemed to be perfect, but today I noted 4-5 pixels on the right side are now gone. I dont know a solution other than instead of investing money in fixing it, to purchase a brand new system. The prices are pretty good now, especially if go to Costco or Sams, or just searching the net for a good price on the model you want to buy.
Chuck
