all you need to do is to get Philip screw driver and remove all screw that connected to the base of your TV after that you can freely remove that base...
Here is a list of codes for your brand of TV, and some steps to program the remote.
1. Hold down the clear TV button until all lights light up at the top of the remote 2. Punch in a 3 digit code (provided below) 3. Press the # (POUND) button 4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board. http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
it seems as though this was indicated as a Maxell,Mitsubshi and or Motorola TV codes. This means that 10835, 0835, 835 or some variant many work with many programmable remote controls.
