Before you conclude that the battery is the problem, i suggest, you get
a similar charger to charge your phone first, if the similar charger
charges the phone, then, ii means you are having charger problem, but
if it does not charge the phone, you should be considering the idea of
getting another battery to see if it will charge on your phone.
The problem can also be that, the charging port of your phone is bad,
you can use your charger to charge a similar phone and see if it
charges, if it does, then, the problem is either th battery or the
charging port.
Check the following one after the other to detect what the problem is,
1. Try use a similar charger to charge your phone to see if it will charge.
2 Get a battery from someone that as a similar phone to test your phone to see if it will power up.
If it works with your phone, get a new battery for your phone, the one you have on it is dead and will need to be replace.
Take care.
