Question about Lexar JumpDrive Classic Portable USB Data Storage Device, 128MB. (PD0128231) Media
My Flash Drive is write protected how to remove the remove write protected from the Flash drive?
Here are some instruction :
-Run Registry Editor (regedit).
-Navigate to the following registry key: -HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
-Create a New Key named as StorageDevicePolicies.
-Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
-Double click on WriteProtect, and set its value data to 1.
DONE :)
To read more about this try looking here : http://www.techyv.com/questions/how-remove-write-protection-flash-drive
Posted on Jun 21, 2012
    President:
  • 1,932 Answers
The procedure for removing the right protection is given in the website given below.
please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
Thanx
Posted on Jul 21, 2010
3 Suggested Answers
SOURCE:
SOURCE: flash drive write protected can't move files
Anyone can help me to my problem with my 2GB imition USB flash drive, it has been writed-protected and there is no switch to disable it, what should i do to this kind of protection. plzzzzz help...
Posted on Nov 21, 2008
  • 11 Answers
SOURCE: Transcend jet flash showing write protected message
hey, i was having the same problem with the same flash drive... there are two ways how you can fix it..
1. try formatting using cmd
Go to start-->run and then type cmd and press enter
now the command window will open
in that type format X: (x being your drive)
This should work fine if not try the second method
2. Go to this website and download the recovery tool software which is exclusively for transcend flash drives.. click the link below to so to that site..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
Download the recovery tool software under the topic software and install it in your system.
Now connect the flash drive in your pc and run the recovery tool application.. This will format your flash drive
Posted on Feb 02, 2009
How to remove write protection
How to tke write protection off a pny attahe? - Hard Drives ...
www.tomshardware.com > Forum > Storage
Tom's Hardware Guide
Sep 22, 2012 - 6 posts - ‎3 authors
Hello, I have a 64 gig attache 2.0 flashdrive. ... I could not see a write protect switch in the PNY product guide, but just ... I've been trying to do this for nearly a year and today found the tool to format my 64GB PNY flash drive. ... the Link you provided and downloaded the recovery tool for my PNY USB 64 Gb ... USB Flash Drive is write protected and shows up as ...
Nov 11, 2012
Remove write protect flash memory USB - Flash Media ...
Nov 30, 2009
More results from www.tomshardware.com
how do i take off my write protection off
Jan 16, 2016 | PNY Attache 64GB USB Flash Drive
How to remove 'write protected' from PNY Optima Pro Attache 2 GB USB 2.0 Flash. My flash drive named above, always tells me that the drive is write ptotected whenever I want to add or remove a...
If it doesn't have a sliding "write protect" switch on it as shown in step 2, try step 5 or step 6 on this page:
http://www.makeuseof.com/tag/how-to-fix-write-protection-errors-on-a-usb-stick/
Small sd cards have a small slider in the case itself. Flash drives may have partitions on the drive itself. One or two of these small partitions may have write protection on them that cannot be removed. If you have too much trouble, put the flash drive in a usb slot, wait for it to be recognized. Open the control panel and open administrative tools. Click on computer management and then in the left lower pane, click disc management. In the right pane, there will be a window that shows and lists all the drives and partitions. Look for your flash drive and you can delete volumes, partition the drive etc.
remove write protected from PNY Optima Pro Attache 2 GB USB 2 0 Flash...
Mar 05, 2018 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
How do you stop a pny 4gb from being write protected
A flash drive should operate just like any other drive. There is not write protect switch on it like an sd card. But, if the permissions have been set to be write protected on a given file or folder on the flash drive, then one can remove it through the control panel.
Or remove and replace the flash drive and make sure it has the latest driver running it.
Good luck on this operation.
Oct 23, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
WRITE PROTECT ERRORS IN PEN/FLASH DRIVE
Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot remove write protection of my transcend 4GB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Flash drive write protect. How do I remove the write protect?
small sd cards have a small slider in the care itself. Flash drives may have partitions on the drive itself. One or two of these small partitions may have write protection on them that cannot be removed. If you have too much trouble, put the flash drive in a usb slot, wait for it to be recognized. Open the control panel and open administrative tools. Click on computer management and then in the left lower pane, click disc management. In the right pane, there will be a window that shows and lists all the drives and partitions. Look for your flash drive and you can delete volumes, partition the drive etc.
Sep 12, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
USB flash drive write protection
Most USB drives don't have a Write Protection switch, but if yours does, then move the slider.
If it doesn't have a switch, the only way to use the drive is to format the drive. First, note the drive letter, such as E, F G for your drive. *** BE CAREFUL *** This will remove all files. Go to Windows Explorer, note the drive letter , Right-click and select Format. Again, BE CAREFUL not to format any other drive, just your removable USB drive.
Hope this helps.
Aug 10, 2009 | Electronics - Others
How to remove write protection from sandisk cruzer flash drive
how do I remove write protection on my cruzer 2GB thumb drive
Feb 21, 2009 | Cameras
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Lexar JumpDrive Classic Portable USB Data Storage Device, 128MB. (PD0128231) Media Logo
4,641 people viewed this question
Top Lexar Electronics - Others Experts
Joe Negus
Joe Negus
 Mike M
Mike M
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
