SOURCE: I pushed the on/off button on my whirlpool tub now stuck
The button is normally an air switch. It is attached to a hose that sends the air pressure from you pressing the switch to a pressure activated switch. This prevents you getting a shock since the wiring is at the motor.
First try using something that vibrates to free it up. Just make sure that it's not something that will scratch the button.
If that doesn't work you should have an access panel to the motor on your tub. Pull this off and look for a clear 1/4" poly tube going into an electrical device. Pull the tube off the pressure switch and blow into it to pop the air switch back up.
