My frigidaire dishwasher model #fghd2433kf1 display says delay 92 clean S and will not do anything. Can anyone tell me ho to rest it
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
We had a similar problem,,,, if you reset the circuit breaker,,, may work, but if not, the dishwasher has a power/control board behind the front cover (6 large round screws) pull front cover off with handle and find smaller square cover,,under that is a board WITH POWER OFF remove board and look on back for a part that is discolored darker than rest of board,, you may or may not see it, this looks like a resister but believe it is a fuse,,, need to order new board from wherever,,, got mine from sears 160.00 worked and was cheaper than someone coming out to do the same thing for more money or buying a new dishwasher. good luck
Dish washer wont start push heavy duty green light lights up push power green light lights up wont start lights stay on about four seconds all lights go off push regular was delay light comes does same thing unplug for ten minutes plug back up press the cancel button press regular wash same thing delay lights still lights up push heavy duty no delay light but still wont start
Thank you for your post, Cathie Sanchez!
I understand that your Frigidaire dishwasher is displaying error code "S" and will not restart. The error code "S" usually stands for sanitize, this could also be a miscommunication within the control panel. I would recommend performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for roughly ten minutes. If you continue to experience issues with the error code I would suggest having a professional technician out for proper diagnosis and repair. Hope this is helpful. -Matt
Hello friend, thank you for your post!
From my understanding the "S" stands for sanitize within your Frigidaire dishwasher. I hope this is helpful. If you have any additional questions please feel free to reconnect. -Matt
Make sure the dishwasher is level. If the water is leaking from the door, you should replace the door gasket.
