SOURCE: comfort-aire Dehumidifier bhd-651
Most likely the fan motor is broke. I have seen several units with bad fan motors.
SOURCE: Fault Codes
This is more of a tip since I have not actually fixed anything yet. As a test, remove the upper front cover where the buttons and displays are. (2 screws on the bottom then pull off a the plastic snaps) Inside the case on the far left, there is a piece of crimped copper tubing, open on the top end, welded to the refrigerant line, with a black sleeve covering 2 wires out the bottom end. This is a thermistor. I CAREFULLY applied heat with a butane lighter (the mini torch kind, not the "candle flame" kind), taking care not to burn anything. I applied ONLY enough to make it slightly warm to the touch. Do not think of melting anything, as this is not the purpose. Applying too much heat could damage the thermistor. With the bucket in place, the unit started right up. After I did this, it failed again in a few minutes, so I heated it again, and thus verifying it as the source. I have done it a third time, never getting it much over room temperature, and it is still running after almost an hour after doing nothing else. Since this temperature sensing is an analog function to the microcontroller that runs everything, the fault could be any bad connection or solder joint along the way from this thermister to the controller. But is sure appears something in thermistor. I hope my description is complete and clear. Good luck.
