Nintendo Wii Console Logo
Posted on Jul 17, 2010
My wii has power but no picyure why? - Nintendo Wii Console
Anonymous
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jul 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
4277
Points
66
Check The cables that connect to the TV. Make sure that the cable is securely connected to the console. Next make sure that if your using the Red, White, Yellow composite cables everything lined up. Yellow is video and should go with the slot labeled video on the TV or the yellow slot on the TV. Red is right audio and should be put in the labeled spot for right audio on the TV or with the red spot on the TV. Lastly white is left audio and should be put in the spot that is labeled left audio on the TV or in the white spot on the TV. If all of the cables are hooked up like so, and everything is secure yet there is still no picture, you need to buy a new cable because it seems that one may have been damaged. If there is still no picture with the new cable, then your last option is to try it with another TV. If it works with the other TV, the 1st TV your trying to put it on has a faulty composite input. If it still doesn't work on the other 2nd TV, then there is an internal problem with the Wii and needs to be repaired or replaced.
Hope this helps!
-MarcusTuttle
MY T.V. HAS POWER BUT NO PICYURE WHY WHAT CAN I DO TO FIX IT
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Faults and possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
I have a 50PL9220D DLP 50". Original problem was picture turned blue and had humming noise. Replaced lamp. Now have humming noise and picyure will come up fine for 5 sec then picture goes out. I have...
Sounds like the unit is going into a thermal protection mode. Probably something wrong with a transformer.
http://www.support.philips.com/support/service/service_page.jsp?userLanguage=en&userCountry=us
What is a tv inverter
the inventer board powers the backlight of your lcd tv to allow you to see it,a faulty inventer board wont send enough power to the backlight causing the screen to be black(if you shine a torch or look carefull you can still see picyure bbut the backlight aint lighting it up)
Is there a master reset on the wii
Instructions
    • 1
      Locate the "reset" button on the front of the Wii console. Hold it down for a few seconds to reset the device.
    • 2
      Wait for the home screen to appear, then hold down the "power" button on the front of the Wii until the power light turns red and the Wii shuts down.
    • 3
      Unplug the Wii's power supply from the wall outlet or power strip.
    • 4
      Leave the Wii console unplugged for at least five minutes. Reconnect the power supply and press the power button to turn the Wii back on and complete the hard reset.
I have checked all three inputs into the wii unit; the power cord, the sensor bar cord, and the rca cords (all three) and I still can't get the wii to come on. The wii power cord shares the same plug as...
The sensor bar cable and the RCA cable can be ignored for this problem. In fact, just disconnect them and go with just the power cable. If you are getting power to your Wii, it will display a green power light on the front when you power it on without the sensor bar or the RCA cable plugged in. (It should also display an orange light when it is off, if it is getting power from the outlet.) Take the Wii into another room with working outlets and plug it in. Attempt to power it on with the power button on the Wii, and with a working Wii remote. If neither will power the Wii on, try borrowing a Wii power cable from a friend, or purchase a replacement. If the new power cable does not fix the problem, see if the Wii is still under warranty and send it in for repair.
1helpful
4answers
The Wii will not turn on.
Unplug wii power cord from wii and wall for 5 minutes
2helpful
Wii not powering off
You have to hold the power button down on the Wii console for many seconds before it will power off completely. Try it for more than 5 seconds.
4helpful
5answers
Power Outage & Now Wii Won't Power Up...
When this same thing happened to me, I unplugged the Wii power supply from the wall (not just from the back of the Wii) and let it sit unplugged for about 10 minutes. When I plugged it back in, everything was fine.
Lcd tv no power no sound picyure
Thank you for responding to my inquiry. I unpluged the tv and left it off all day , when I pluged it in the power light came on and it is working now.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
