Panasonic TC-P42U1 42 in. Plasma HDTV Logo
A
Anonymous Posted on Jun 27, 2010
Panasonic TC-P42U1 plasma. Lost it's vivid colors basic color is black and white and green and blue if tint color tone etc. Is turned up. However a blue ray video plays with full color. Could it be a lose or faulty cable?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
857
Points
I have an old Toshiba TV and was going to replace it with a new plasma because it has suddenly (the week of July 19, 2010) lost color. It has only green and blue tint. Changing the "tint" on the menu didn't help. The color comes and goes relative to nothing that I can measure, such as how long it is turned on, etc. Reading other complaints from owners of Plasmas, I am thinking it is cable related. I have Charter Cable. Playing a DVD, I have to readjust the tint back to normal. Hope this info gives clues.
2helpful
Color code for panasonic model cq5301u [wiring code] i just need to know what colors are speakers wires right left front back etc.etc.and key hot and always hot wires or the color code for all the wires...
okay here it is
on all aftermarket radio they follow a color code
iginition 12 volts red
constant 12 volts yellow
ground black
remote wire amp turn on blue/white stripe
speakers
Lfront + white
Lfront - white/black stripe
Rfront +gray
Rfront _gray/black stripe
Lrear +green
Lrear -green/black stripe
Rrear + purple
Rrear - purple/black stripe
some radio have other wires too
like dimmer wire orange
power anntenna blue
and some flip screen radio have parking brake wire green
since your needing a wiring diagrame i would take it to a mecp professional 12 volt installer to install radio . about as fast as you blink your eyes you can fry the electrical system in your car and cost you 100's or 1000's of dollars buy and rewiring you car to fix it .
[email protected]
for more questions
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Cannot adjust color
Have you turned the controls from one of the presets? Presets are Vivid, Movie, etc. Most sets have to be in Custom or Customize to adjust the controls, likely on-screen with one of contrast, brightness, color, or tint selected. If those are horizontal bars then up/down selects which and right/left select decrease/increase or red/green for tint. Start with 50% if no reset (0% for R/G) or start with the non-Vivid settings. Consult AVS forums for you model to get better settings. Rules of thumb: Brightness should be as dark as possible without losing gray scale at lowest part. Contrast should not be so high that whites bloom or make it hard to see. Color should not blow out any color nor be unnatural. Tint is best judged on flesh tones. -Ken
1helpful
Lost manuel to canon powershot A630 and I wanted to know how to take a black and white picture.
By pressing the center button on the four-way controller, you'll open up the Function menu. This menu has the following options:
  • ISO speed (Auto, High ISO Auto, 80, 100, 200, 400, 800) -
  • White balance (Auto, daylight, cloudy, tungsten, fluorescent, fluorescent H, underwater, custom) -
  • Drive (Single-shot, continuous, self-timer [2 or 10 sec, custom] -
  • My Colors (Off, vivid, neutral, sepia, black & white, positive film, lighter skin tone, darker skin tone, vivid blue, vivid green, vivid red, custom color) -
  • Flash exposure compensation (-2EV to +2EV in 1/3EV increments) - in manual mode you can adjust the flash strength in three steps (1/3, 2/3, full)
  • Metering (Evaluative, center-weighted, spot)
  • Compression
  • Resolution
- Lisa
http://www.dcresource.com/reviews/canon/powershot_a630_a640-review/
5helpful
2answers
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
2helpful
2answers
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
2answers
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Optimal Settings
Picture +13
Bright +9
Color -3
Tint -1
Sharpness -10
Temp Normal
I think this provides the best color to my eye, by everyone will be a bit different. For instance, I think factory Vivid is too saturated (like most LCDs) and the whites in Cinema are too blue. It's personal choice really.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
