Question about Samsung Televison & Video
Samsung 5 series 40 remote not working
My samsung 5 series 40" TV remote does not work. Cells r brand new, I have cleaned the front IR sensor. Request
assistance
  • 11,361 Answers
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
Posted on Jul 17, 2010
SOURCE:
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
I have just bought a brand new remote for my Phillips 42 inch LCD tv from a reputable phillips website as the old one was not working (I recently bought it from my mate and his kid had eaten the on button...
Sounds like the IR sensor in the TV may be faulty, since you have now tried a couple remotes. Make sure nothing is on the IR sensor like tape, plastic, etc. IR sensor repairs are a fairly cheap and easy repair that can be done at your local tv repair shop. If you are still in warranty you can call Philips and tell them that you tried 2 remotes (1 brand new) on the TV and neither work. They should offer you a repair option. If you have any questions regarding your Philips warranty let me know.
Jul 18, 2011 | Philips 42PFL5332D 42 in. LCD Television
My remote control (BN59 - 01014A) work only on short distance (1 - 1,5 m). I have a TV Samsung Led UE26C4000. I have changed batteries several times, but no results. Please help ! Thanks
Take the tv remote aparts,there is a screw in the battery compartment.I know this because i have a tv this model too.Take some Q tips soak it with some rubbing alchahols and clean the remote PCB board and wait like about 20 mins for it to dries.Put it back together again and with a new set of batteries.And take some cottons balls soak it with some rubbing alchahols and clean the tv set infer red light sensor on the tv set it self too by the tv LED power light indicaton.This solution should improve ur infer red senor reading like( 2-3 more m).
Jul 14, 2011 | Samsung Bn59-01041a Remote Control
Remote control stopped working so i purchased a new remote control that doesnt work so now i am presuming it is the tv sensor itself
Brand of the TV? Yes it can be the IR receiver or the REMOTE switching jack if it has one in the back of the TV.
1) Test the remote:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
2) If the remote checked out OK, then look at the back of the TV for the "REMOTE INPUT", use a mini-phone plug and insert the plug ino the remote input jack in and out a couple times to clean the switch contacts that select between the front IR receiver of the TV or the rear panel IR input jacks.
See: http://www.fixya.com/support/t9056223-remote_doesn_39_t_work_all
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Apr 28, 2011 | Televison & Video
Samsung ua46c8000 tv ir/sensor dose not work
Good day!
Please follow this procedure to find the exact problem.
  1. Check the battery of the remote.If your battery is 1.5vdc x2,the reading should be 1.5vdc x2 also! or 1.4vdc,tolerance to response the remote.Replace the battery if it is below on the tolerance voltage.
  2. Check the IR sensor using a digital camera or cell phone camera.
  3. Place the camera in the front of IR sensor then push any of the button to activate the remote.If your IR sensor flashes on the camera it means you IR sensor is good if not flashes on the camera replace it.
I hope this information will be helpful.Thank you very much.
Apr 18, 2011 | Samsung Bn59-01041a Remote Control
TV IS NOT RESPONDING TO REMOTE. I'VE CHANGED THE BATTERIES AND HAVE TRIED OTHER SAMSUNG REMOTES THAT WORK ON MY OTHER TVS. ANY SUGGESTIONS...
Sounds like problem is with TV. Make sure the remote sensor on the TV is not blocked, it is located at the lower right part of the front of the TV.
Dec 12, 2010 | Samsung BN5900696A Remote Control
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Jul 28, 2010 | Televison & Video
DS27930 27" TV: I have a Sanyo DS27930 tv and the remote hasn't ha...
check the remote control for any rust on the contact terminals of the dry cells.If present sratch it off and place back the cells and see if it operates.if it does not work you can easily identify the between the tv or the remote what is mulfanctioning by testing the remote for ir radiation,simply by directing the remote to a camera sensor of your mobile phone,if ir light is seen as you press the buttons then the remote is good and if not then the remote is faulty and might need technical expertise to repair.however if you see the ir light ,the problem lies with our set
May 18, 2010 | Sanyo DS27930 27" TV
My REMOTE CONTROL FOR TV HAS VERY WEEK RANGE CAN I MAKE IT POWERFULL
Try replacing with new Cells ....
and clean the IR LED of the remote ...
clean the IR receiver of the TV tooo.
basic range is 15feet it should work if it is working
Sep 28, 2009 | Televison & Video
Remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Jul 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
656 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
