It could be that it is not charged correctly. Check the insulated copper
line outside if it is sweating and the condensor is discharging hot air, then the ac is doing all that it can. Check the evaporator inside to see
if the drain has condensate coming out of it.
Getting the heat out of the attic is a good idea, but you must have enough make-up air in the attic for the fan. If you do not have enough
make up air, it will start to draw air from inside the house. One way to check this is if you have a gas water heater and or furnace. If you put
a flame by the exhaust pipe in the basement and it blows it out, then you now have a backdraft problem.
Run the AC withoutthe fan, my real guess is the unit is not properly
charged or you do not have a big enough AC unit.
Goodman model CLJ42-1C
Have you checked the indoor coil. It may be dirty. You can buy coil cleaner that you don't have to rinse off for the indoor coil. Did you clean the coil on the outdoor unit. Also check the fan to see if it looks like it is running fast enough. Let me know what you find.
