SanDisk Sansa Fuze MP3 Player Logo
A
Anonymous Posted on Jul 14, 2010
After I downloaded my pics on the sansa it gave me this message when I tried to view pics on device:"usupported media format"
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • SanDisk Master 102,366 Answers
  • Posted on Jul 16, 2010
SanDisk Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442950
Points
622693
You need to use the supplied Sansa Media Converter program to convert your pics (and videos) to a format the Sansa can handle.
Its not playing videos
First step --
Download a PDF copy of the Sansa View manual. Here's a link:
http://www.google.com/search?client=ubuntu&channel=fs&q=sansa+view+manual&ie=utf-8&oe=utf-8
There are two likely reasons for the video not to work;
1) The software that runs your Sansa View, known as 'firmware', is outdated;
2) Your video requires conversion before you download it.
1) Firmware update?
Download a copy of the Sansa Firmware Updater from here:
http://kb.sandisk.com/app/answers/detail/a_id/4431
Start it on your computer, and follow the directions to update your Sansa View's firmware, if needed.
2) Download and install the Sansa Media Converter (SMC) from the same link above.
--Plug in your Sansa View to the computer, and run the SMC.
--Follow the directions to select your video. SMC processes one video at a time for upload into your Sansa player.
Another possibility - Try loading video from Windows Media Player 11;
From the manual, page 17--
"Your Sansa View player supports MPEG-4 Simple Profile up to VGA, H.264 Baseline Profile up to VGA, and WMV up to QVGA video formats.
That means you can simply drag and drop these files into the Video folder if you are using Windows Media Player 11."
Hopefully, that will help you get your videos in!
Why don't all myp pic load on sansa mp3
You need to use the supplied Sansa Media Converter to convert your pics (and videos) to a format the Sansa can handle.
2helpful
When I try to look at pics that I have downloaded onto my MP3 player, the screen says unsupported media format. What should I do, so I can view my pics
You need to use the Sansa Media Converter to convert the pictures to a format the Sansa can handle. If you don't have the SMC, you can download the Windows version from http://www.megaupload.com/?d=3IPZO6Q0
I can't put pics on unsupported media format
you need to use the Sansa Media Converter to convert photos (and videos) to a format the Sansa can handle. o to the Sandisk site look under support.
I am trying to upload wmv video files to my Sansa View mp3 player, but I am getting a message: 'unsupportable file format'. What would be the work around for this?
Use the Sansa Media Converter. If you don't have the SMC, you can download the Windows version from http://www.megaupload.com/?d=3IPZO6Q0
I downloaded pics but it says I'm not useing tha right format when I try to open the pics on my sansa. and to visit this site for support.
For getting pics into the right format, software is required called Sansa Media Converter.
How to get this software.
Through updating with Sansa Firmware Updater: this will give you all updates for software and manuals on the computer and the firmware for the player.
Install the Sansa Media Converter for converting.
See also next link for how to load videos and photos:
http://kb.sandisk.com/app/answers/detail/a_id/101/kw/media%20converter/r_id/101834
1helpful
Sandisk view : access denied''
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe).
try this
Freezes after 8 secs (No sound or anything)
I registered my Sansa View in sandisk site, and the support sent to me these two solutions. I have a similar problem like you and I'm still haveing problems but meaby these steps working in your sansa view.
regards
Diego
Nr 1:
Let us update your player's firmware:
Step 1 – Connect the player in Recovery Mode.
1. Turn off the player.
2. Slide down the Hold switch along the left side of the player down so the orange is showing.
3. Press and hold the HOME button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer (XP) or Computer (Vista).
5. Release the HOME button.
Download and update the firmware.
1. Download the firmware file:
Click Here for the Sansa View Firmware update file
2. Extract the zip file.
3. Copy the extracted firmware files (*.dat, *.rom, *.mi4, and *.fnt) to the 16MB-FORMAT drive.
4. Disconnect the player. This will now start the firmware update.
5. Slide the Hold switch to the unlock position.
6. Turn on the player.
Nr 2:
It appears that this is caused by file corruption in your player's memory. Usually, formatting your mp3 player resolves this FM issue in your player.
Formatting your Sansa View Mp3 player in Disk Management:
WARNING - FORMATTING YOUR MP3 PLAYER WILL ERASE ALL MEDIA FILES IN YOUR PLAYER, PLEASE BACK UP IF POSSIBLE.
1. Make sure the Sansa View is turned on.
2. Engage the hold switch, located on the left-hand side of the player.
3. Press and hold the LEFT BUTTON ( << )
4. Connect to the computer while pressing and holding the LEFT BUTTON ( << ). Do not let go of the left button until the player is detected as Removable Disk.
5. The Sansa View should now be connected in MSC mode and should appear as a "Removable Disk" or "Sansa View".
6. From the desktop, right click My Computer, then select Manage. If you don't see My Computer on the desktop, click on Start and right click My Computer from there, then select manage.
7. On the Computer Management window, click Disk Management from the left pane.
8. On the right side, locate your sansa device on the list (it might be recognized as removable disc), right click on the sansa device, then select Format.
9. On the Format Window, select FAT32 under File System and make sure that the Quick Format option is not checked.
(You might get a warning window about your files being deleted when you format the device, if that is not an issue for you, click ok.)
10. Click OK to start formatting the device. This should start the format process.
11. Once the formatting is done, unplug the device from the computer. Let the device refresh.
12. We can verify that formatting is successful if it shows no files on the player.
2answers
Royally screwed up e260
help! i have tried to download my copied cds through rhapsody & windows media player. nothing happens in rhapsody & windows gives me an error occurred message after each song when i try to copy to e260.
thanks for your input,
trish127
Won't hold pics or vids
You have to use the Sansa Media Converter to "convert" the files to a recognizable format. Standard image formats do not work. The Sansa Media Converter is on the installation CD. Best of Luck.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
