This issue occurs when the list of the entries is max and you have to delete some entries in the web sessions.. then try to install the update.
if you are using the Airtel Connection, delete the others like, idea gprs, vodafone etc...
if you are not able to delete them (if it is locked), then select edit and enter the required fields. you can know the values of those fields from your service provider. (airtel, voda etc..)
then , you can go online for sure..
At first call to your customer care executive to send you for internet settings for your mobile. When you recive the settings then do the following things-
After that Install Pc-Suite and
