Polycom CX700 IP Phone Logo
A
Anonymous Posted on Jul 07, 2010
Hi I have a problem about CX700 starting failure it just stay in the screen:office Communicator phone edition.
Emerson 475 Field Communicator. I have a bootup problem.
Question edited for clarity.
Hard Resets and Reboots
JM Test Systems https://jmtest.com > PDFs > hart-475-field-com...
Use this method to shut down and reset the 475 Field Communicator if the screen appears to lock up and does not respond when you use the touch screen or keypad.
134 pages
HART 475 Problem - CR4 Discussion Thread
GlobalSpec https://cr4.globalspec.com > thread > HART-475-Prob...
Dec 22, 2015 - first, push the Fn and backlight buttons simultaneously to reboot the device ... If you can not recognize the original or not, see the Series NO., ...
Further help and support here
https://www.transcat.ca/emerson-475-field-communicator-475fp1eklugmts
Transcat is pleased to be able to offer our customers Easy Upgrade capabilities for the life of your Emerson 475 Communicator.
Emerson will support the 475 communicator through the end of September, 2020. Transcat is able to support your 475 communicators with Easy Upgrades purchased from Transcat now and beyond September, 2020.
What does this mean?
Emerson will continue to add DD's (device drivers) to the Easy Upgrades through September, 2020. Both Emerson and Transcat can perform your Easy Upgrades during this time. Starting in October, 2020, while there will be no additional DD's added to the Easy Upgrade offering, Transcat can perform the Easy Upgrade on any 475's purchased through Transcat after September 2018 with the available DD's as of 9/30/20.
Is there a setting that automatically shuts Sharktooth motorcycle bluetooth communicator down when paired?
Unfortunately, there is not a setting that automatically shuts down the Sharktooth motorcycle bluetooth communicator when it is paired. However, you may contact Shark to see if they can provide a software update for the communicator that might address this issue.
I need the part number for the laptop MSI CX700 LCD bracket (right)
No two PCs/Laptops are equal, so if I were to give you a part No. without knowing your PC/Laptop hardware, I'd be giving you generic information, and not the specific info you require.
My best advice is to take the unit to your nearest PC shop/repairer and they'll find this for you and give you a quotation as to cost of part and cost or repairs.
I hope I have been helpful.
Cheers,
Peter
Need a driver for CX700 polycom IP phone, sites says no driver needed but Windows device manager shows unknown device. Where is the driver for this, need it for Win 7 64bit.
what you need to do, is update the firmware of the device.
This is a good guide:
http://www.ocspedia.com/Misc/Update_Server_Check_List_R2.htm
Cannot start the 9500 communicator
maybe the flexible, but flash your phone first
2helpful
My lcd screen on my new msi cx700 keeps flickering and going black. if i press the top corners of the screen bezel the screen returns to normal.Could this be a bad screen, backlight, inverter, something...
This may be due to the inverter board found behind your lcd panel.
Take it apart & solder the two sides of the coil found on the inverter board. This loose solder is caused by heat.
Please send me your feedback & vote to motivate us & to help us help you.
2answers
2helpful
2answers
Error system on the display when I rebooted nokia 9500
hi there try this reset code for a nokia communicator phone like your 9500 just enter this code *#7780#
1helpful
Office communicator
forums.microsoft.com please visit and seesome tips have been given or you re install the Microsoft Office Communicator 2005 again or for more details visit support.microsoft. therethey have been given solutions ortry this .com for detail
www.codeproject.com
www.tacktech.com
www.peterdehaas.net
please try this wed sities
bye
Top Polycom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
