Creda Colonial 42352 23 in. Electric Cooktop Logo
Posted on Jul 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Creda 100 lp cooktop. The igniters keep clicking when the knobs are turned off. The clicking stops when one of the burners is ignited. What is the repair?
Anonymous
Level 3:
President:
  • Master 1,561 Answers
  • Posted on Jul 16, 2010
Anonymous
Master
Level 3:
President:
Answers
1561
Questions
0
Helped
296320
Points
4482
  1. Check that the stove is plugged in, there is power to the outlet, and the circuit breaker hasn’t tripped. Spark ignition oven need electricity to power the igniters. If your oven light turns on, you have power.
  2. Test if the switch is at fault by turning a functioning burner to the “Light” position while simultaneously turning the one that’s not working to “Light.” If the burner that wasn’t working now comes on, the burner has a bad switch. you will need to replace the switch.
Take care.
Hello, My Creda cookertop ignition system has a problem . There are 4 burners on this CT. 2 diagonally across burners cannot ignite when their knobs are activated but they show sparks of ignition when the...
(1) Get Naval Jelly (Rust dissolver) and apply on the igniter and than see if everything is fine.
(2) Check the connections from the knob to the burner. Probably have a leak. Replace the wire from the knob to the burner.
Feb 02, 2011 • Cooktops
After spraying stainless steel cleaner on the cooktop, with the knobs removed, the igniter won't stop ticking as if it's trying to ignite. All the knobs are securely in the off position. Could this be...
Yes, the moisture is probably the problem...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
1helpful
Creda stovetop tries to light without gas on.
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
3helpful
2answers
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
2helpful
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Trouble with Kenmore Gas Cooktop
hi there,
the clicking noise is the spark module trying to ignite. i would get a technician to come and check it.
Sep 28, 2008 • Cooktops
Top Creda Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Creda Cooktop Expert? Answer questions, earn points and help others
