GE MiniCam Pro HO98756 Webcam Logo
A
Anonymous Posted on Jun 30, 2010
The disk driver will not auto run the set up disk
Khurram Shah
Level 3:
  • GE Master 10,322 Answers
  • Posted on Dec 13, 2012
Khurram Shah
GE Master
Level 3:
Answers
10322
Questions
0
Helped
1467340
Points
20232
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Windows keeps finding new hardware nd trying to install it. I put in the disk, but xp won't use the files
Run the driver from the disk by clicking on the execution file ..or running the auto-installation ..and only attach the printer when it asks or after the driver is installed ..
Or ...plug the printer...and let the wizard start ..select not to look for the driver on the net ..but to select it from a location ...click the case that will alow to browse for a location ..and point the search to the disk drive ..and click next ..this way you will force windows to install the driver for it ..
If on the disk are several drivers for more than one operation system ..you will have to select when browsing the driver folder and specify the xp one ..
I want to install xp2 in compaq presario cq40, but a blue screen is show
Hello Download the SATA driver for your particular chipset. Then download nlite (just google it). Install it and follow the directions to slipstream the driver into your installation disc. You can also add SP3 and all the drivers you need to it.
or go to bios and restore it to default setting if you have a sata hard disk then disable it in bios setting or RAID Auto/Ahci to RAID Auto/ATA then reboot from installation disk or You can get help from this site http://www.laptops-drivers.com/compaq/how-to-install-windows-xp-on-hp-compaq-cq40-115au.html
hope this helps
I just installed a MAG 17 incuh flatscreen monitor to my Dell Dimension 3000. When I turn the PC on, the monitor disploays everything on the desktop,but then goes black. If I turn the monitor on and off,...
I think that you have chosen some settings that are not compatible on it ..resolution too big and probably the refresh rate high ..
first from the monitor settings ..press the auto-settings button ..and let it make the proper choice ..after that ..to eliminate any settings in the video card that might affect it ..boot your computer in safe mode..and remove the video card driver from control panel ...add /remove programs ...and after that run it again from the disk or ..from teh support site if you do not have the disk ..
If you only have the on board driver..and you do not have a disk ..run it from the drivers of the motherboard disk ..This will reset the odd choices on the video card ..and make it work ..to open in safe mode..press F12 on start ..and choose safe mode..(for some computers the button is F9 or F8 )Usually the button is specified when it boots up ..
But ..for to be sure that this is the cause...you have to hear to computer running ..and only the display to be black ...otherwise can be a physical fault..
I want to set up My Favorite
You will need the Driver installation Disk for the wireless Keyboard and start the auto run from the CD. According to your operating system install the proper drivers from the Disk.
1helpful
How to install canon ir3300
just run the disk that came with the printer into the computer ...and when it asks plug the printer into USB or whatever cable it has....You can even plug it first and run the disk after ..but usually this will cause the computer to run the installation wizard and it may be a little confusing..but not too much ...if you choose to do so ...just cancel the auto-wizard ...and run the disk ...be sure that the printer is plugged and on ..when you install it ...the rest will go auto ..after you finish just restart the computer ...It will print a trial with the specifications first ...
If you do not have the software for it ...here is the link where you can download the driver suitable ..
http://software.canon-europe.com/products/0000714.asp
just select the operation system you have in use...than submit ...Download the driver and install it ..
I have changed my Internet provider and it has a different IP address than before and my bizhub 250 cannot print now
Press Utility/Counter
Press Administrator
Input code 12345678 or 00000000
Select admin 2
Select Network
Here you can change the network settings to match you new Network scheme. You will have to reinstall the print drivers after you correct the network settings. If you have the driver disk it will auto run and find the machine, if you don't have the disk you can download the drivers at kmbs.konicaminolta.com where you can also download the user manuals in PDF format that will go into more detail on changing the network settings.
1helpful
Konaki gp-36 mp3/mp4 camera is not recognized by usb. No drivers came with device and vendor states disk was not part of purchase.
If disc was not part of the purchase as is the case lately the software is on the unit's drive.Try a different usb port and if the drive shows up on your PC set it to Auto Play open files to see files in folder then you can run setup if not auto.Try a different PC running...Windows XP or VISTA.Good Luck.
2helpful
2answers
Can't open game
In the disk you should find a setup file or .exe file to install the game, the autorun file is just to tell the PC to run the file. Have a look for it
If you cannot find it please post back.
Good luck and thanks for choosing FixYa!!
No operating system found
This is caused by :-
1. Your hard disk has failed.
2. Your BIOS settings for the hard drive has been altered
3. Your hard drive has been wiped or someone or a virus program that has deleted critical files.
Go into your BIOS setup to check the hard disk settings, if possible see if it will auto detect the hard drive.
Also boot up with a DOS disk run FDISK to see if you can detect a hard disk, partitions etc.
If the hard disk appears OK you may be able to do a disk repair, most likely you would need to re-install the operating system and the laptop drivers for video, audio, LAN, modem etc.
Can't get Student version to auto-set up
There are a number of bugs with Vista and the later versions of Office (like 2007). Try running "setup.exe" from the Office disk and use great caution before installing SP1 for Office 2007 since the SP1 auto-install can cause problems with Vista.
Top GE Computers & Internet Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
