2000 Isuzu Rodeo Logo
Posted on Jul 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Isuzu rodeo 2000, LS, anti-theft alarm needs to be reset
2000, LS isuzu rodeo anti-theft alarm needs to be reset
Anonymous
Level 2:
  • Expert 82 Answers
  • Posted on Jul 16, 2010
Anonymous
Expert
Level 2:
Answers
82
Questions
0
Helped
28921
Points
262
This has to do with the Auto's Computer system and should ONLY be done by a Factory Rep who knows what he/she are doing. not a home mechanic chore!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3126
Points
The alarm in my Izuzu Rodeo LSE go on at any time. With no apparent reason. How I control this. I need to put the key all the time to shut it off.
Cassandra Baumann
Level 1:
New Friend:
  • Posted on Mar 03, 2019
Cassandra Baumann
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3126
Points
How do I reset the security on a 2000 isuzu rodeo?
How can I reset the anti-theft alarm?
TELL THE PROBLEM FIRST. MUST WE GUESS?
DOORS DO NOT LOCK OR UNLOCK ????
KEYFOB BATTERY DEAD
OR IMMO KEY DEAD. 1 OF 2 FAILS OR BOTH KEYS FAIL.
ENGINE DEAD AS IMMO DOES ITS JOB
WHY NOT LEAD OFF WITH SYMPTOMS
anti-theft DOES LOTS OF GOOD AND EVEN MORE BAD THINGS
A HUGE LIST. (HORN HONKS AS YOU SLEEP AND MORE)
How do you make the a/t oil temp light go off on a 2004 Isuzu rodeo after fixing the problem
You can try disconnecting the battery and see if that resets it. You will need to reprogram your radio possibly so have your anti theft radio code handy if your car is so equipped
Could having a factory anti theft system and a alarm system in a 2000 isuzu rodeo cause problem because mine will go off randomly and nobody is around
Your alarm system should have a sensitivity setting screw, if you can locate it, it's probably buried behind your dash. If you adjust the sensitivity it might help with the problem.
2answers
Anti theft wont let me start car
The problem may not be with anti-theft but with a bad fuel pump,cam/crank sensor etc. Also, you may try unlocking the drivers door with the key. On most cars that is the standard method for disabling the security system.
How do I know that the anti theft system in my 2001 Isuzu Rodeo is working ?
One way is to row your window down, step out of the vehicle, press lock on your key fob, reach inside the window, unlock door and open door. The alarm should go off.
How do you reset the factory anti theft system? I purchased a used isuzu rodeo that has the anti theft sticker on the window and the blinking light. The person that i bought it from didn't have a...
Most cars that are mid 90s and newer had a remote feature. If you take it by the parts department of and Isuzu dealer they should be able to order you one or two.
2answers
2000 Isuzu Rodeo (just purchased), anti-theft alarm goes off periodically for no apparent reason. Was going to remove fuse, but it is already gone. How can this be possible, unless someone has bypassed...
THATS WHY THEFT SECURTY ALARM GOING OFF THEFT SECURITY SYSTEM NOT WORKING FUSE IS MISSING.MORE LIKELY THE GUY SOLD YOU THE CAR BECAUSE OF FAULT IN THE THEFT SECURITY SYSTEM, GOING COST TO FIX.
How do i deactivate anti theft system in my 99 isuzu rodeo
you would have to change the body control module ,re program it and then not reprogram the anti theft system portion.
2answers
2000 isuzu Rodeo wont start
Could be your neutral safety switch, or it's not all the way in park. Broken or loose wires in the starting circuit. Inspect all wires and connectors at the battery, starter solenoid, and ignition switch. Or your starter pinion is jammed in the ring gear. Remove starter and inspect. Last but not least, your engine is seized. You don't want that one. Good luck.
3helpful
Anti theft dash light is blinking on my 1998 rodeo and will not start now. Tried unhooking battery to reset, but no luck. Will not crank from jumping off either. Battery is good, all lights and the radio...
I'm assuming its an original alarm or system that came from factory or dealer. When the light blinks is because the alarm is activated. Look underneath the radio the alarm brain might be there. There will be a label on it saying alarm or security system etc. Disconnect the harness to it and try operating your vehicle.
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
