Question about E-Machines eMachines Desktop PC
T6420 bad on board video red is out Does it make sence to put a new video board in this machine
E0machines T6420 bad on board video red is out Does it make sence to put a new video board in this machine
    Problem Solver:
  • 95 Answers
If you want to continue using the machine it does. If not time to get a new one.
Posted on Apr 20, 2008
SOURCE:
Frigidaire Affinity ultra capcity front load washer is not sencing the load it spins but the light stays lit on load sencing and will not fill with water! I have tried getting an error code with no luck!...
If your problem is No water coming IN the machine, then it is One of your two water inlet valves need replacing. Feel the water that IS NOT coming in. That will tell you which valve. Cold only water means the Hot water valve is bad. If the water is NOT leaving the machine it will not spin and you need a New drain Pump installed.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Feb 10, 2014 | Washing Machines
No red color red is black pink i sblue
E-Machine tech support are the same as Gateway Support. their answer to to reload always. sounds like a trouble video card or Monitor. try plugging in a different monitor and see if you have the same result. Make sure to check the pins on the video cable to verify none are bent. if you get the same results. you have a bad video in the computer. If it is, I believe that the video is actually integrated into the mother board, you can purchase a new video card and plug it in, that will automatically disable the onboard video.
Apr 03, 2010 | E-Machines eMachines Desktop PC
I am in need of network driver for the Emachines t6420, please?
The motherboard in the machine is an MS-7207
The chipset drivers are nForce 430/410
You can download the chipset drivers from nVidia here >>>>>>>>>
http://www.nvidia.com/object/nforce_nf4_winxp32_8.26_11.09.html
Don't worry, the network (LAN) driver is included in the package.
Regards.
Sep 03, 2009 | E-Machines T6420 PC Desktop
My t6420 has not been plugged in for 2yrs and I started itup today and the fan on the board runs all lights are working but can not get a display on my monitor
you can try to reset cmos.the cmos jumper is in most cases near the battery on the motherboard.or,if you dont know how to move the jumper remove the battery for 3 minutes and put it it back.if the problem persists you might have a problem with video card.
Aug 29, 2009 | E-Machines T6420 PC Desktop
Gateway GX7018E / T6420 = swap video cards for a test?????
No you cant, the gateway GX7018E uses integrated graphics like the T6420. You will have to buy a cheap PCI or PCI-E graphics card to test it out.
Jan 02, 2009 | E-Machines T6420 PC Desktop
Emachine - T6420 - Monitor on stand by, no picture, fan running non stop, hard drive power on, screen blank, monitor in yellow not green the programs would end after 10 seconds---if you opened...
Most likely your video card is broken. To check if the motherboard isnt broken either, I would suggest you test usb, sound, and other features of the motherboard.
 If your motherboard isnt broken then you have to buy a "pci-e graphics card" at your local store. Shouldnt cost much, about $40-70. Hope that helps.
Hi, i am workiing on an emachine T6420 for my brother and this thing starts up with the fans running and a black screen. my monitor that i connected to his computer shows a yellow standby light on the...
That's exactly what it sounds like. I would put in a new video card (or used one, if you have one) into one of the expansion slots and run it from there.
I would suggest to go into VGA mode just to make sure, but since your monitor never even gets off standby, I'd be 99% it's the onboard video.
Hope this helps!
Dec 28, 2008 | E-Machines T6420 PC Desktop
Emachine t3112 only work in safe mode
you need to run the new hardware wizard as there are differnet drivers needed for the mb
Dec 19, 2008 | E-Machines T3112 (RBT3112) PC Desktop
Motherboard for a e-machine t6420
CPU: AMD Athlon™ 64 3400+ Processor (with AMD 64 technology)
(2.20GHz, 1600MHz system bus, 512KB L2 cache) Operating System: Genuine Microsoft® Windows® XP Media Center Edition 2005
Chipset: NVIDIA® nForce™® 410 Memory: 1GB DDR (2 × 512MB), 400MHz dual channel
Expandable to 4GB Hard Drive: 200GB HDD (7200rpm, 2MB cache) Optical Drive: 16x DVD±RW multiformat double layer drive Media Reader: 8-in-1 digital media manager (Secure Digital™ (SD), smart media, micro drive, memory stick, memory stick PRO, compact flash, multimedia card, USB 2.0) Video: NVIDIA® GeForce® 6100 GPU
up to 128MB of shared video memory
PCI-Express® (PCI-E x16) slot available Sound: 6-channel (5.1) high definition audio Network: 10/100Mbps integrated Ethernet LAN (RJ-45 port) Modem: 56K ITU V.92-ready fax/modem (RJ-11 port) Peripherals: Premium multimedia keyboard, 2-button wheel mouse, amplified stereo speakers Ports/Other: 5 USB 2.0 ports (4 in back, 1 in media reader), 1 VGA external connector, 1 serial port, 1 parallel port, 2 PS/2 ports (keyboard and mouse), 5 audio ports (2 in front, 3 in back) Dimensions: 14.25"H x 7.25"W x 16"D Weight: 22.5lbs
LInk to spec page : http://www.e4me.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6420
Sep 29, 2008 | Brother CS-8150 Computerized Sewing...
E-Machines eMachines Desktop PC Logo
63 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
