You have a bad control or line voltage not all the way there. Check and reset breakers. Check where it plugs in and check the voltage going to stove at cord if all checks good for 230volts. If all checks are good: replace electronic oven control, its about as tough as plugging in a pc phone modem just do one wire at a time so you don't get confused. Good luck.
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
