Problem solved-click on this link, and follow instructions:
http://www.tomshardware.com/forum/42649-43-find-buffalo-router-password
Check the wireless router for the security key and insert
SOURCE: router
I use a second wireless card for just such issues.
the internal cards antenna is weak.
toshiba seem to be the worst about this to me.
SOURCE: Can't connect
It will be one of two things or both - either your computer is notsetup for DHCP or your router is using the same IP address as your ISPor both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
Toconfigure your computer to use a DHCP IP address, go to the Controlpanel => network connections => Properties (right click on yourdefault connection) => double click Internet protocol (From generaltab) => (a new window pops up) from the general tab ensure that"obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
SOURCE: resecure network
first enter the router ip adress in iternet explore. You will need to know the username and password to change the setting for you router.
SOURCE: Buffalo Airstation G54 wireless is not working
connect your computer straight to your internet modem.
If it works then connect the router after reset....
read the manual..if it does not work then return your router and get a new one or simply buy netgear..has been working for me Without problems for 4 years other than two years ago got fried due to electrical over charge
