Question about Nokia C5 Cell Phone
How to flash nokiac5 - Nokia C5 Cell Phone
  • 5,081 Answers
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
Posted on Jul 15, 2010
SOURCE:
How can i open my javasetting in my nokiac5-03 touch symbian
Hello you could not open JAVA,because this application is Copyright....and generally this software is installed when the operating system (OS) is installed.Thanks for visiting fixya
Aug 30, 2012 | Nokia Cell Phones
How to get gprs seting in my nokiaC5-oo?
Just put ur phone in a tub or a drum full of water... after that put in the table, and get a hammer then smash it..!!!!! ................ and you have good, new, condition and quality phone...
Jul 30, 2011 | Cell Phones
Howw to format nokia c5 phone memory?
Hello thanks for using FixYa
To format dial *#7780# or *#7370# which restores the factory settings. it will ask you to confirm that press OK. it will take some time and your handset will be format & restored to original settings.
But if you format the whole phone memory then follow the procedure below
First of all Switch off your phone then press and hold 3 keys combined
  • Green dial key
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the phone.
  • In the process don't leave the 3 press and hold keys, After some time the phone will format completely
Note: Remember one things this will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then restore it.
Default security code for nokia is 12345
See my TRIP & TRICK to format Nokia Handsets which will help you out briefly
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 29, 2011 | Nokia C5 Cell Phone
My nokiac5 mobile is not able to access to internet
Please check back the internet settings. Get operator help if needed
Jan 27, 2011 | Nokia C5 Cell Phone
I miss my memroy card password so how to opena ma card
you can get your MMC password through FExplorer.
U just do this step.
  • Firstly, you need to install FExplorer, a free file manager that allows us to browser through S60 file system.
  • Next, launch FExplorer and then browser to c:\system folder. There is a file, calledmmcstore.
  • Rename the file to mmcstore.txt and then open it. Your password must be several characters at the end of the file.
Jan 04, 2011 | SanDisk 2GB microSD Memory Card
Check engin light
it is flashing the codes if you got the sequence right it is codes 12,21,55 what engine? 12 battery disconnect,21 isO2S shorted to voltage, and 55 is MIL may not come on
Mar 05, 2010 | 1995 Jeep Grand Cherokee
My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
Mar 05, 2010 | Washing Machines
Check engine on jeep grand cherokke 1995
Try again and verify, for example.
3 flashes,pause,then 3 more, is 33. etc.
5 flashes, pause 5 more, is code 55.(end of message)
always 2 digit number, then slightly longer pause in between those 2 digits.
Feb 23, 2010 | 1995 Jeep Grand Cherokee
Led with number 9 displayed is flashing
LED 9 flashing can mean many things. Here is the list of "flashing codes" for the vostro 1510.
Keep in mind a flashing led is going to blink 3 times. for example,
number one would look like this:
On (solid lit). Blink, blink,blink (paused off) blink, blink, blink... (paused off), (then repeat)
1. ON-FLASH-FLASH = No Ram or ram not seen
2. ON-FLASH-ON = Ram has a problem
3. FLASH-FLASH-FLASH = Motherboard failure (replace board)
4. FLASH-ON-ON = CPU Fault/failure
5. FLASH-ON-FLASH = LCD detect failure/fault
6. ON-ON-FLASH = MINI pci card (controller) failure/fault
7. FLASH-FLASH-OFF = Keyboard fault/failure
8. FLASH-OFF-FLASH = USB FAILURE
9. FLASH-FLASH-ON = Video BIOS or BIOS issue
10. ON-FLASH-FLASH = Modem issue
Depending on the blinking code, you might just need to re-seat or replace your RAM or your CPU. But then again, you could have a more severe motherboard issue.
Nov 01, 2009 | Dell Vostro 1510 Motherboard System Board...
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Nokia C5 Cell Phone Logo
269 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
