Samsung SyncMaster 931BF LCD Monitor Logo
Posted on Jul 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to open case/shell of Samsung SynMaster 931BF???
I have a Samsung SyncMaster 931BF. I love the screen, but for quite awhile, the screen has been having a hard time coming on and staying on. I'll have to cycle the power multiple times to get the screen to stay on and it's getting really bad now. I have read that the problem is either capacitors, the power supply, or the backlight, with it most likely being capacitors. My problem is that I can't figure out how to get the screen's case to open to see inside! I have tried everything in the repair manual (the actual manual technicians use) and unfortunately, it doesn't just "lift off" b/c it catches on something inside. Anyone know how to open the dang thing up?!?
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jul 18, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366074
Points
33650
You remove all the screws, stand, then useing the thin flat blade screw driver to crack open the case, starting at the bottom edge and work your way around, it is hard to tell you in words. Try Youtube also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
I have a Samsung SyncMaster 931BF. I love the screen, but for quite awhile, the screen has been having a hard time coming on and staying on. I'll have to cycle the power multiple times to get the screen...
Remove its stand
Unscrew all the screws in the back.
It doesnt just lift off I guess you could say, there are many clamps around the edge that need to be "popped" by sliding anything thin enough to get between the front and back of the case to pop them.
I popped mine open the other night. The clamps appear to be hard to break, at least in my circumstance. None of them broke with a fair amount of pressure from pulling being applied.
Also, mine had your exact same issue until one day it no longer turned on completely. It just flashed the screen once and showed a flashing power light around the button. Replacing 3 capacitors that were just barely bulging on the top fixed the issue.
Samsung Syncmaster 740NW vertical blue stripe
I've never opened one of these units, but I think you're right...a broken, cracked, or "cold solder joint"...had that problem on boards a lot of times. What has been assembled, should have a way of disassembling, unless the plastic was molded or glued after assembly, which is almost never the case, to my knowledge. Sometimes screws are hidden under labels, paper or metal plates, anywhere, really. If you can drop by a computer repair shop, you might be able to pick their brains about where the screws are, just depends on the person working there. Only other choice is to get the repair manual, but they're expensive and hard to locate, sometimes. Anyway, keep working on it, I think you'll figure it out!
I can't get my Samsung SyncMaster 931BF to come of of sleep mode?
I already post solution for this problem, click here to see the solution.
Syncmaster 181T periodically shuts down
monitor ACER 17" S/N #ETL460C148710572-B4045 just off for minutes at a time. Please solve this.
2answers
Samsung lcd monitor
If you know to electronics, open it and look for cold solder joints in the horizontal and vertical transistors. apply fresh solder and ready for two more years.
Samsung SyncMaster 750S
1. check tha VGA cable is properly connected into the computer
2. possibly CRT board dry solder. you can touch up the solder joint
2answers
Synmaster 740 n green line on the monitor
This may be part of the OSD (on-screen display). If you don't have your manual you can download it here: http://tinyurl.com/yzerbd I would check the manual.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
