Remove its stand
Unscrew all the screws in the back.
It doesnt just lift off I guess you could say, there are many clamps around the edge that need to be "popped" by sliding anything thin enough to get between the front and back of the case to pop them.
I popped mine open the other night. The clamps appear to be hard to break, at least in my circumstance. None of them broke with a fair amount of pressure from pulling being applied.
Also, mine had your exact same issue until one day it no longer turned on completely. It just flashed the screen once and showed a flashing power light around the button. Replacing 3 capacitors that were just barely bulging on the top fixed the issue.
SOURCE: How to open case/shell of Samsung SynMaster 931BF???
You remove all the screws, stand, then useing the thin flat blade screw driver to crack open the case, starting at the bottom edge and work your way around, it is hard to tell you in words. Try Youtube also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
