Braun 7000 Series Foil and Cutterblock Logo
Posted on Jul 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Batteries run down faster (Braun 7505)
Need to replace batteries in Braun model 7505. How do I open the device, etc?
shaveroutlet.com
Level 3:
  • Braun Master 1,652 Answers
  • Posted on Jul 15, 2010
shaveroutlet.com
Braun Master
Level 3:
Answers
1652
Questions
0
Helped
765682
Points
4209
You will find batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To open the shaver body, you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out. Reassemble in reverse order
  • Bill Maroney
    Bill Maroney Dec 30, 2014
    Very helpful...Brector's instructions were perfect. Here is what I can add: Once we get the razor disassembled, clean the contacts. Mine were covered with just enough stubble to insulate the contact and break the power connection. I wiped down the contacts on the shaver head piece and within the razor body -- and the razor turned on in my hand, only partially assembled. The contacts are located to the bottom left of the razor head as it lays down in the body -- batteries up. Very quick and simple solution worth checking before buying new batts.
Bill Maroney
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Dec 30, 2014
Bill Maroney
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
2191
Points
1helpful
2answers
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 screws
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
3helpful
I need a new battery for this razor. I know its replaceable, but where dose it go and how do you get the cover off?
You will find the correct battery type for model 7505 at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
You will need two batteries. Scroll down the item page for videos showing disassembly and installation tips
1helpful
3answers
How do I open my Braun 9585 Pulsesonic shaver to replace the battery??
Hello
Remove the electrical cord from the base of the shaver.
Press down and slide off the panel on the front of the shaver.
Remove the two nickel-plated batteries. Use these batteries as a guide to purchase new batteries at a hardware store or home repair store. Recycle the old batteries when finished. (Many hardware and home repair stores have battery-recycling stations.)
Put the new batteries inside the shaver and press gently to pop into place.
Place the front panel back on the shaver and plug the electrical cord into the bottom of the shaver. Connect to an electrical outlet to charge.
THANK YOU FOR VISITING FIXYA
I have a Braun Flex XP 5614. It´s some years now, and I have to charge almost every second day. I thought it would be smart to change the batteries, but how? I have removed the two screwes, but I...
You will find the correct batteries for model 5614 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-battery-nimh-2-batteries-p-105.html
To open shaver, first remove the two round or oval screw covers on the bottom of the shaver. Then remove the screws underneath, The can then slide the outer case of the shaver down and off of the shaver inner body exposing the batteries
2helpful
Braun 7505 switch won't slide down to off position. battery has to run down to stop. What can I do?
Guest solution (2008) to Pry out the blue button worked great for me. Not sure what the semi-circular shapes under the button were for but the switch works fine now. The only down side was that prying the button off broke the tab holding it, but this is no big deal. Saved me the cost of a new razor and I like the Braun 7505 model because it works great and is smaller than some of the newer models.
7helpful
Charging does not work and is immediately empty
I believe that you are stating that your model 4775 Braun shaver no longer holds a charge. To repair this you will need to replace the batteries. To replace the batteries, you will need to open the shaver up. First, remove the two round plastic screw covers on the bottom of the shaver then remove the screws that are underneath. The outer casing will then slide off the bottom of the shaver. You will then be able to access the batteries.
You will find batteries for model 4775 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nicd-2-batteries-p-454.html
1helpful
Shaver not charging.
The batteries should not really get warm. You may not have a good solder connection
Assuming that the batteries are in correctly with good solder joints, the problem is likely the motor. With the shaver fully assembled, remove just the foil and cutter and then turn the unit on. Use your finger to push the piece of plastic that the cutter fits into back and forth. If it starts and moves slowly or if it stutters, the brushes in the moto are probably bad. Because the motor is a sealer unit, the motor will need replaced. If you require this part, you will find it at shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-7000-series-syncro-motor-drive-unit-p-110.html
2answers
Braun Syncro 7505 Shaver, Need Power Cord.
If you just need a eplacement cord, you can get one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html
If you need batteries or PC board, this will raise the price considerably and you may find a less expensive option of buying a replacement. You will also find similar replacement units at shaveroutlet.com
5helpful
3answers
I just need to know where I can get new batteries for my braun syncro 7505. The batteries don't have any markings telling the volts or milliamps. I would greatly appreciate it if someone could help me with...
Yes, these are NiMH AA 1.2V flat top batteries. Replacements can be found on some battery websites (like onlybatteries.com). I'd get the 2200mAh rated ones, as they'll hold a longer charge than the 1650mAh ones. You will need two of them (the shaver has a 2.4V motor). This works for most Braun shaver models from 6000 to 8000.
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
