Fridge and freezer stopped cooling so I unplugged for couple of days to defrost as it had ice build up on bottom of freezer before it stopped cooling. Plugged back in and it worked fine for about 5 days before it stopped cooling again. What can this be? this is a side by side about 10yrs old
SOURCE: water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small
amount of cold air will be forced through the frost but that will not
be enough to make it up to the refrigerator portion. You can defrost
the unit by removing the metal panel and allowing the frost to melt.
Careful use of a hairdryer can speed up this process. This will likely
be a temporary fix. The root cause of excessive frost can be caused by
a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar
bill at several points around the door, both on the freezer and
refidgerator door. If you can pull the bill out with no resistance, the
door is not making a good seal. Inspect the seal and make sure there
isn't anything stopping the door from closing such as food, or a shelf
not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The
defrost system has three main parts, the defrost heater, thermostat,
and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually
starting the defrost cycle. Let me know if you would like this
procedure.
SOURCE: fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
SOURCE: Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
SOURCE: model 501-64822 is a self-defrosting Kenmore that
Hi, Look that model # up again please. The problem you are having is the defrost drain is plugged. Remove the rear panel inside the freezer and melt all the ice. Locate the drain hole and flush it out with hot water. Some modles need an after market drain heater kit. Get me the model # and I can look this up for you.
Vic
So first thing you try is , perform,
manual defrost reset procedure.---------
The manual defrost
reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit
completely. Then keep both the doors open. Wait for 24 hours. All the ice
collected on the coils and in the freezer section will get melted.
Clean the water from the sections. Then Connect the power cord of the unit to
main power outlet after 24 hours/.Then set the temperature to normal in both
fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again
building up ice that means the unit is not defrosting. It's starting the
cooling procedure, and then while defrosting, it's not working. The defrost
assembly consists of three main parts. The defrost thermostat, the defrost
heater and defrost board. Any of the one is not functioning. When thermostat
sense the maximum cooling, it triggers the defrost heater to start heating and
this defrosts the ice collected on the coils and the system works. Both
thermostat and heater are controlled by defrost board. First the
thermostat and defrost heater to be checked, if both check ok by meter and
visually, then its defrost board causing the problem. You can get
required parts from from online sites like:
--- www.repairclinic.com or from searspartsdirect online site. --------- This
should help.Thanks.Helpmech.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out the water running tip...
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
