this problem can be solved by pressing the yellow button,then enter 107 and hold down the red button till the screen changes to copy SP,press OK or 1.The macine will now be in service mode.switch the machine off then on again.if it go into SC541 again the problem lies with the thermistor of the fuser unit
Depending on the model, you may just have to enter service mode, and power off/on. For older models you will have to enter service mode, and then run SP5-810, then power off/on. That is assuming that the fuser problem has been repaired prior to running the codes.
