SOURCE: Steady squeaking noise after taking foot off accelerator
sounds like you have a pad rubbing on a disk/rotor, if you jolt the brakes does the noise go away? if so it's probably a pad loose
SOURCE: Saturn l200 Steering Wheel Squeaks
On the intermediate shaft. Steering shaft there is a rubber boot where it goes thru the firewall. This rubs, sometimes can be lubed with a silicone spray, sometimes needs the shaft replaced.
SOURCE: squeaking noise underneath in front
that sounds like the squeler fo the brakes and you might want to check to see if they need to be changed and/or have you had them changed yet?
SOURCE: 2006 Saturn Vue squeaking when I turn the wheel R or L
That sounds like a power steering issue. Does it make the sound when the car is stationary?
SOURCE: I am hearing a clicking noise from the front end,
Get the cv joint checked.It sounds like that is the problem.I would also look at the brakes.If the sound is worst when you turn right,it may be the cv.This is on a left hand drive vehicle.I hope this helps
