Hotpoint 23 in. BFV62 Built-in Dishwasher Logo
Posted on Jul 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hotpoint dishwasher mod BFV620W starts then pumps out water,and the second and forth lights on control panel flash non stop
adrian halligan
Level 3:
Genius:
  • Master 1,075 Answers
  • Posted on Jul 14, 2010
adrian halligan
Master
Level 3:
Genius:
Answers
1075
Questions
Helped
278982
Points
3080
Go to hotpoint web address and they will tell you.i would suspect main circuit board.adrian,,,,
2answers
Ariston dishwasher LFB 5B010 EX on/off, rinse aid and salt lights are flashing, left washing light orange and green (end) light on without flashing.
It sounds like there may be a problem with your Ariston dishwasher. The flashing lights and the dishwasher's inability to wash could be caused by a number of issues, including a problem with the control panel, a faulty water inlet valve, or a clogged wash pump.
To troubleshoot the issue, you can try the following steps:
  1. Check the control panel for any loose or damaged wires. If you find any loose or damaged wires, try to secure them or repair them as needed.
  2. Check the water inlet valve to make sure it is not clogged or faulty. The water inlet valve controls the flow of water into the dishwasher. If it is clogged or faulty, it could cause the dishwasher to stop working.
  3. Check the wash pump for any blockages. The wash pump is responsible for circulating the water during the wash cycle. If it is clogged, it could prevent the dishwasher from washing properly.
Jan 02, 2023 • Dishwashers
My FINLUX C13 reset button keeps flashing and cycle stops wat could be wrong and can I fix it myself, thank u
Dishwasher lights flashing or blinking. The heating element heats up the water to operating temperature. If the water doesn't reach the proper temperature after a set amount of time, a light on the control panel might start flashing. ... If the drain pump is not working, a light on the control panel might start flashing.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/28---/Dishwasher-Lights-Flashing-Or-Blinking
https://www.youtube.com/watch?v=5-aH_tVbYi8
Apr 17, 2020 • Dishwashers
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 24, 2013 • Dishwashers
1helpful
My dishwasher starts ok then stops 2 flashing lights appear on control panel does anyone know why
Possible that the inlet valve, inlet filter is clogged and so there is low pressure or flow of water into the washer. Secondly the water level sensor can be faulty and so since there is no detection the processor is shut down..
4helpful
2answers
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
2answers
Dishwasher keeps pumping out - won't start cycle - green light flashing on panel
I had same symptoms on a Hotpoint dishwasher.
Turned out to be a failed water heater.
The logic in this case goes like this:
When wash cycle starts, the first thing the machine does is pump out any water that has collected in the sump since it was last run.
It then allows a small amount of clean water in and enables the water heater.
If heater okay, it then continues with the rest of cycle.
In this case, the control board detected failed heater so pumps out the water and then stops with an error code shown by a flashing lamp.
No simple fix I'm afraid - machine had to be turned on its side, bottom panel removed, several items had to be removed to get at the water heater which was then repalced with a new one.
You dont state what make/model your dishwasher is so maybe worth adding this information as someone else may recognise your fault and have a quick fix.
Oct 02, 2009 • Dishwashers
2helpful
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 • Dishwashers
6helpful
Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Jan 26, 2008 • Dishwashers
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
